hello!
I have a little question...does anyone know how to make DVD-samples to have in your main menu (while the user can choose between play the movie, choose subtitles, choose chapters...)
michcio
Results 1 to 15 of 15
I use DVD MovieFactory:
I set-up my menus with a background video that I have previously created from sections of the main movie. -
thanks for your answer
but how does your samples look like are they just a part of the .avi file or are they as "real" samples (many parts from the .avi file "glued" togheter). Because I would like to learn how to create this "real" sample easly
I use GUI for dvdauthor as my authoring software... ok I'll take a look at Vegas
ok...but hm how do I create DVD samples in Vegas .. to me Vegas seems to be a difficult program with many functions...how do I create a sample?!
I don't understand your question or what you mean by sample.
If by sample you mean a short clip of highlights from a movie then what you need to do is extract them scenes you want from your DVD, put them on the timeline in Vegas (or whatever editor you like to use), trim them down, and arrange the order (edit them, in other words), then output a new video ready for using in your DVD.Read my blog here.
yeah that was what I didn't understand...and I wonder if there is a tool that make this pice by pice building easier
Try Windows Movie Maker - very easy to handle. And output to DV avi.
No tool can guess what scenes you want to include in your sample. -
yeah thats what I use to..ah ok then nevermind I'll continue using windows movier maker
thanks and regards
michcio -
If you want to start off with a single clip, without peicing anything together, download dvd shrink and use shrink to "grab" a short clip/segment of the movie and use that for your background.
yeah I make this kind of animated backgrounds as well but I use Boilsoft Video Splitter to cut of a part from my movie
LFE audio samples, are there any samples to download and try
By wetduck in forum Newbie / General discussionsReplies: 0Last Post: 14th Mar 2011, 09:17 -
What do you call these kinds of vocal samples?
By takearushfan in forum Newbie / General discussionsReplies: 3Last Post: 5th Jul 2010, 19:43 -
Motion² - first samples!
By nitro1973 in forum Software PlayingReplies: 1Last Post: 25th Apr 2010, 16:00 -
Video Codec Samples?
By prdffy in forum Video ConversionReplies: 8Last Post: 8th Mar 2010, 03:52 -
Make samples ?
By yabbah in forum Newbie / General discussionsReplies: 1Last Post: 27th Dec 2009, 06:41
