Dear all
I would like to do the following while preserving the original video/audio quality:
1) Extract the existing audio and video tracks from a DVD
2) Modify the audio track (probably using Audacity or similar, depending on the audio format)
3) Burn the DVD using the original video track and new audio track
Can anyone recommend software that can do the above? I am primarily on a Mac, but have access to a PC if need be.
Many thanks
Greg
I find your proposition that you can "modify" an audio track "while preserving the original quality" to be dubious and unlikely to be correct.
The following guide describes how to add a subtitle to a DVD and keep the menus, etc. While you don't have to do that, you can follow the same process just by substituting your new audio file for the original one. -
tinker: Thanks, I will take a look at Muxman.
jman98: I should clarify this. I would like to extract the audio track without degrading the quality further. I then plan to modify parts of the audio track while leaving the remaining parts alone. The result that I am after is that the unmodified sections of the audio track should be of equal quality to the source DVD (i.e. I don't want to rip the DVD audio to MP3 or any other lossy format). Do you have a link to the guide?
Thank you both for your suggestions. -
Sorry for not providing the link earlier. I thought I did that.
https://forum.videohelp.com/topic275603.html
Not sure what you mean by "modify parts of the audio track", but you need to be aware that if you delete/replace anything, the length will probably change and you'll have sync problems. -
Thanks, I'll have a look at that article.
The length will be staying the same, I'll just be replacing sections of background music with different music, which will fade out at the point the old music finished. -
gregbolshaw wrote:
IF the new/modified audio track is in the LPCM format, and if the filesize fits on theI would like to extract the audio track without degrading the quality further. I then plan to modify parts of the audio track while leaving the remaining parts alone. The result that I am after is that the unmodified sections of the audio track should be of equal quality to the source DVD
remainder of the DVD's filesystem, THEN it will be possible to get what you're looking for.
The DVD-Forum specs also allow the use of .ac3, .mp2 and .dts for the audio part,
and none of these schemes for audio compression is lossless. -
Hey, here's a tutorial that I think explains just what you're looking to accomplish:
http://backstar.com/blog/2009/09/01/edit-video-on-an-existing-dvd/
It outlines the process of demuxing, editing, remuxing, and replacing media files on an existing DVD.
The best part: This is a totally lossless method, so you will not lose any image or audio quality if you follow the steps outlined in the tutorial.
Hope this helps!
Converting Multiple Audio Track MKV's to avi without Quality loss
By OrtegaSeason in forum Video ConversionReplies: 4Last Post: 6th Feb 2011, 08:09 -
edit dvd without losing quality
By robroth in forum EditingReplies: 8Last Post: 13th Jan 2011, 14:12 -
Get audio track from DVD Extra instead of film sound track in VIDEO TS
By Josephine in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2010, 13:25 -
Adding an audio track without losing quality?
By smackyourfupa in forum Authoring (DVD)Replies: 14Last Post: 26th May 2010, 06:28 -
Add audio track without losing menu?
By levon in forum Authoring (DVD)Replies: 3Last Post: 1st Feb 2008, 05:26
