The drivers for this new Dazzle DVD Recorder USB device won't install to my Win2k machine. I knew it didn't have support but I hoped it'd still install. Anyone know if this is possible?
I'm trying to get the output from my DirecTV box into my PC so I don't have to buy a new TV to watch it in my bedroom. I don't need a tuner, since I'll be using the box and I don't care about recording it. I just want to use my PC to view the output of the DirecTV box. Doesn't seem that complicated but apparently it is.
Anyone have a better, cheap idea if this won't work? I have an old ATI TV Wonder VE card installed but never could get it to work either.
Thanks.
Jason
Check the Dazzel support site for a Win2k driver. If you have a PCI slot most any BT tuner card will have Win2K drivers.
http://www.kiva.org/about -
Yeah, the support site only has the same XP or Vista drivers that came with the device. I know the PCI cards should have the support, but like I said, the one I already have I can't get to work and I'm on my second capture device. I'd like to hear if anyone has had any luck with a simple, cheap solution. If it's more than $100 I'm inclined to just buy a dang TV.
Thanks,
Jason -
Consider a LCD/TV that has a tuner AND can double as a bigger/nicer computer monitor. That's my suggestion. Might run $300 or so.
Where can I find one of those for $300? I can find the TVs or the Monitors but haven't seen one that will do both.
Thanks. -
Try "Pinnacle Studio". It contains more drivers than its website's list. Good luck.
Thanks genki500, but are you suggeting I should buy the $100 Pinnacle Studio software with the hopes that it will have a Windows 2000 driver for my $50 Dazzle device? If I've got to spend $150 I'd rather just buy an LCD TV. If I misunderstood please let me know.
Thanks.
DVD Recorder & Cable Box
By pepegot1 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 19th Oct 2010, 18:43 -
Dazzle DVD Recorder - not good enough?
By OneSoccer in forum Capturing and VCRReplies: 3Last Post: 12th Jul 2008, 15:59 -
Ulead VideoStudio 10 + Dazzle DVD Recorder = No Sound???
By firebirdta84 in forum Capturing and VCRReplies: 1Last Post: 18th Jan 2008, 09:26 -
dvd recorder and dvr box setup help
By backdrop001 in forum Newbie / General discussionsReplies: 3Last Post: 5th Dec 2007, 11:29 -
DVD Recorder, The Tv and The Sat. Box (HELP)
By lostgoddess in forum DVD & Blu-ray RecordersReplies: 7Last Post: 5th Nov 2007, 00:17
