Will making color and sound corrections in "MPEG Video Wizard DVD" affect the video resolution once exported to DVD?
No (and yes). Making adjustments to colour, or anything to do with the image other than simple cut edits, will force a re-encode. If you have your settings correct, resolution should not be affected, however depending on your bitrates etc, quality may be reduced.
If you don't have your settings correct, resolution may well be changed. Make sure you have your settings matching the source video (For NTSC Full-D1 it should be 720 x 480, with an aspect ratio of either 4:3 or 16:9)Read my blog here.
First "Action Video" with Effects
By gree in forum EditingReplies: 4Last Post: 28th Apr 2011, 11:51 -
New "editing box", need advice on best use of multiple video cards.
By jaybird in forum Newbie / General discussionsReplies: 0Last Post: 10th Apr 2011, 22:16 -
The effects on the video "take on me" by A-ha
By dunnotck in forum Newbie / General discussionsReplies: 15Last Post: 18th Nov 2010, 15:25 -
DVD with menus, replacing "bad" video with "good" video
By chipsndukes in forum Authoring (DVD)Replies: 34Last Post: 4th Dec 2008, 18:45 -
Compatible Burner for Womble's "MPEG Video Wizard DVD"?
By cyberboy in forum Authoring (DVD)Replies: 3Last Post: 4th Jul 2008, 23:25
