Hello, I have a couple of FLAC files...(full discographies etc) and I wanted know if I can make a DVD Audio with them, maybe convert into wav with DVD compilant format, what software should I use to author (with menus maybe???), if I can play it in my standard DVD Player, and the most important of all, is this possible?, I know I can burn them into DVD data and play them into PC, but I wanted make a DVD audio....
Thanks,
Use this to extract the WAV file,
Trader's Little Helper (free)
Click the link and it will take you to the download.
Once extracted you can use something like this to make an audio dvd,
Audio DVD Creator (not free)
It will convert the audio files from 44100Hz (cd audio) to 48000 Hz (needed for audio dvd playback)
Make a dvd structure with menus, ect. and will burn it to the dvdr or you can make a temp folder and burn with Imgburn.
That would be the fastest and easiest way to do it.
Or if you want to take a lot of time there are free ways also.
Splitting FLAC audio format.
By greator in forum AudioReplies: 7Last Post: 4th Aug 2016, 09:28 -
Need Help Converting Audio 44.1KHz LPCM flac to 48KHz LPCM + Add to DVD
By nagysaudio in forum AudioReplies: 2Last Post: 5th Oct 2010, 10:15 -
Ripbot Flac for Audio - volume too low
By AndyD in forum Blu-ray RippingReplies: 2Last Post: 10th Sep 2010, 20:55 -
Best lossless audio codec - FLAC? Will it kick out mp3?
By Srivas in forum AudioReplies: 6Last Post: 25th Feb 2010, 09:40 -
DVD to FLAC/SHN/WAV?
By Salva Veritate in forum DVD RippingReplies: 1Last Post: 26th Sep 2007, 23:56
