If it still has pixelation something else is probably causing it. Try posting a sample.Originally Posted by tripecac
Results 31 to 41 of 41
http://www.kiva.org/about -
Okay, CBR 9800 looks the same as the others. The fact that these encoding settings have no apparent effect on pixelation makes me wonder if the problem is somewhere else...
So I found a way to get the Preview window in Vegas to expand almost to full screen. This lets me check for pixelation in the capture itself.
And guess what... The pixelation is there. In the capture, the DV-AVI file. I just don't notice it on the standard TV for some reason. But I see it on the screen.
So this means the pixelation is being introduced in the capture rather than the encoding. Sigh. I feel like I just wasted a bunch of time! (mine and yours)
I guess this means I need to go back to my capture thread:
https://forum.videohelp.com/topic353032-30.html -
I looked at the sample images from Hi8 to DV and didn't see any significant macroblocking. The last three images in this post:Originally Posted by tripecac
https://forum.videohelp.com/topic353032.html#1863600
DV can show a little macroblocking but far less than any DVD MPEG conversion. But reading your last post on that thread I don't think you are talking about macroblocks but rather interlace comb artifacts which are perfectly normal in interlaced video. It your video is processed properly on the way to DVD you will not see the artifacts on TV. -
Try to cap some stills or a few frames of MPeg2 to illustrate the problem.
You might want to try a better quality Hi8 sample tape to test the capture chain.
Do I understand correctly that your capture chain looks like this?
Hi8 camcorder ---(S-Video)--->MiniDV camcorder---(Firewire)--->Computer
And you monitor this way?
Computer---(Firewire)--->MiniDV camcorder---(S-Video)--->LN40A650 or CRT SDTV
And the problem doesn't show with direct connection?
Hi8 Camcorder ---(S-Video)--->LN40A650 or CRT SDTVRecommends: Kiva.org - Loans that change lives.
I posted a still here:
https://forum.videohelp.com/topic353032-30.html#1865277
I've been posting back in the capture topic, since the pixels seem to be capture related. Sorry for splitting it up like that! -
Yes! Pass-through doesn't seem to degrade the quality any more than recording to MiniDV first and then transfering to PC second.Hi8 camcorder ---(S-Video)--->MiniDV camcorder---(Firewire)--->Computer
Computer---(Firewire)--->MiniDV camcorder---(Composite-Video)--->SDTVComputer---(Firewire)--->MiniDV camcorder---(S-Video)--->LN40A650 or CRT SDTV
My PC isn't near the HDTV, so I can only monitor on the SDTV.
Hi8 Camcorder ---(Composite-Video)--->LN40A650 or CRT SDTVAnd the problem doesn't show with direct connection?
Correct, I don't see the blocks, just general graininess (which I don't mind as much). -
I don't see blocks, just resized interlace. A non-issue if you avoid deinterlace or resize.
That seal pic has extreme contrast.
Any more examples?
PS: The composite monitor connection introduces NTSC cross color artifacts. No S-Video connection?Recommends: Kiva.org - Loans that change lives.
I posted another screen grab in the other topic, this time using the copy-to-clipboard feature. It's 720x480, so isn't being resized.I don't see blocks, just resized interlace. A non-issue if you avoid deinterlace or resize.
By the way, I'm not embedding screen grabs in the posts; they're links (hosted on tripalot.com). Here's the 3 latest:
http://tripalot.com/issues/images/20080708-capture-blocky.gif
http://tripalot.com/issues/images/20080708-capture-blocky-2.png
http://tripalot.com/issues/images/20080709-capture-blocky-3.png
If I zoom in on these, I can definitely see (what I call) blocks, particularly in the lower left near the edge of the railing.
Seal? Do you mean the one taken at 9:21:50AM ? That's a guinea pig!That seal pic has extreme contrast.
http://www.flickr.com/photos/tripecac/sets/72057594095168211/
It's pretty dark in the guinea pig room, so I wouldn't be surprised if the colors are all over the place.
My TVs don't have S-video, just composite (and component in the case of the HDTV). The only S-video connection I have is between the 2 camcorders.The composite monitor connection introduces NTSC cross color artifacts. No S-Video connection? -
Hi, a couple questions:
1) As instructed previously, I turned off deinterlacing. In my last two DVD tests, I've been noticing the pixels a lot more. It might be my imagination, but they seem more prominent. I'm viewing them on a HDTV (1080p). If my main viewing TV is progressive scan (HDTV), should I turn deinterlacing back on? Are there other settings I can tweak to favor HDTV?
2) For some reason, Vegas has been rendering deleted frames (see https://forum.videohelp.com/topic353834.html ) -- I'm wondering if this is related to the interlacing (or de-interlacing). -
If you deinterlace now you will forever be stuck with the result. As much as half the temporal and spacial resolution of your source will be lost forever. If you leave your video interlaced you will retain all that information. Your current HDTV will deinterlace in some manner as the video is being displayed. It may not do a particularly good job now but deinterlacing techniques are improving with time. Your next HDTV will likely do a better job.Originally Posted by tripecac
If you are making DVDs to watch now, and plan to keep your DV tapes/files then this isn't a big issue. Do whatever works best for you now. But if you don't plan on keeping the DV tapes/files the DVDs will be all you have. You will want to preserve as much of the Hi8 data as possible.
Interlaced material does require more bitrate than progressive material. -
So is there a chance that getting Vegas to deinterlace will help reduce pixelation on my HDTV?
The deinterlacing is just for the rendering, right? It doesn't chance the source video. So it's only DVDs (and web-targeted videos) which will be affected. Correct?If you deinterlace now you will forever be stuck with the result.
I intend to keep the raw captured DV-AVI files forever, on hard drives (with one set offsite). Those are my "master" copies from which I will generate DVDs and web videos. The DV-AVIs are what need to be as pristine as possible.
The DVDs are just for testing and viewing. I expect to burn updated versions over time, as I get better at editing and rendering. I won't be trusting DVDs as a primary backup.
So, given that DVDs are (in my mind) disposable, and I'm trying to get them to look good on a specific HDTV, is deinterlacing a good idea?
Does Converting MPEG1 2 MPEG 2 improve quality?
By purpleronnie in forum RestorationReplies: 10Last Post: 7th Aug 2009, 16:47 -
VHS to DVD - is there any way I can improve quality of conversion?
By rairjordan in forum Capturing and VCRReplies: 21Last Post: 13th Feb 2009, 13:32 -
Will an up-scaling DVD Player improve quality?
By W_Eagle in forum DVD & Blu-ray PlayersReplies: 15Last Post: 4th Jul 2008, 16:23 -
Can a DVD recorder improve TV quality?
By Try4ce in forum DVD & Blu-ray PlayersReplies: 6Last Post: 21st Jun 2008, 22:16 -
will changing bin files to dvd improve sound quality?
By motleycool in forum Newbie / General discussionsReplies: 1Last Post: 15th Sep 2007, 05:40
