Hi. I received some xvid videos from a relative from a family member. The videos were out of sync. In VLC's advanced audio settings i set the audio syncronization compensation settings to 5 and it was back in sync. How do i re-encode the video so that change is permanent?
Any help would be greatly appreciated. Thanks
http://www.pcpodcast.org (Website Under Construction)
QTSync (free) works for QuickTIme videos:
http://www.qtsync.com/Al Bloom -
You can use avidemux to resync but a + difference in VLC corresponds to a - one in avidemux.
Launch avdmx, leave the Video and Audio options on the left as copy, check the shift box below Audio and enter the correct compensation. If your movie has more than one soundtrack you'll need to select the rrequired one from the Audio tab in avdmx's menu bar but I believe you get a prompt if that's the case anyway. -
Sorry, but avidemux in my experience is very buggy on my mac. It crashes when you try and import a videoOriginally Posted by ffooky
Audio Sync Problems
By eon_designs in forum Blu-ray RippingReplies: 2Last Post: 8th Dec 2009, 09:49 -
Audio sync problems
By jelockwood in forum ffmpegX general discussionReplies: 1Last Post: 30th Jul 2007, 12:03 -
Audio sync problems
By alvinboobar in forum Video ConversionReplies: 1Last Post: 10th Jul 2007, 06:22 -
I've got audio sync problems (too)
By gigantibyte in forum EditingReplies: 26Last Post: 10th Jun 2007, 10:17 -
Audio sync problems (again!!!)
By MadMaz in forum Newbie / General discussionsReplies: 10Last Post: 30th May 2007, 20:42
