I recently had issues with a Gigabyte GA-MA69GM-S2H based HTPC where I would lose video signal but the unit would stay powered on. I think it may be a result of an overheated Northbridge. In any case, I'm RMA'ing the board and have ordered an Asus M2A-VM HDMI, largely because it uses the same chipset.
Do you think I will have any issues or problems by swapping a GA-MA69GM-S2H for the M2A-VM HDMI board?
PMA400 Tips and Tutorials
ATI AIW x800 XT -
As long as they are the same form factor you should have no problems.
Same chipset or not...XP will search for new drivers if it needs them, just don't force it to use the drivers you think are right ..if it says they are not.
Note: I had a simular board (may be the same but I can't rem model number) that would randomly go dark, fans and all still running, but no video and no response (sound, ect..) almost like it was going into some suspend or power saving mode.
I had let the person who was to use the PC install the operating sytem and programs ( he seemed inteligent enough) well after that happened I expected some type of driver conflict, or that he had enabled some wierd stuff......so I sugested he reinstall OS. Same thing happened again.
Long story short: I formated drive and reinstalled OS myself and it has not done it once since?? Don't know what he was doing but it was messing with some thing vital.
recommendations for swapping audio from MKV files
By tkolt in forum EditingReplies: 3Last Post: 22nd Mar 2011, 05:39 -
Stream swapping
By P8tterns in forum Video ConversionReplies: 4Last Post: 20th Jul 2010, 20:01 -
H264: tool for swapping frames without re-encoding?
By fvisagie in forum Video ConversionReplies: 9Last Post: 23rd Feb 2010, 20:52 -
Question about excessive file swapping
By jimdagys in forum ComputerReplies: 10Last Post: 19th Sep 2008, 09:02 -
Swapping a Toshiba HDD
By next in forum DVD & Blu-ray RecordersReplies: 4Last Post: 24th Jul 2007, 06:49
