  1. Member Alexius's Avatar
    Jul 2008
    Canada
    I'm converting a H.264 MKV file entitled "[sudo] Spice and Wolf 01 [DC4F4905].mkv" to a VOB using the target format "DVD mpeg2enc". The only changes I did to the options was checking "VOB Subtitles" on the 1st track for Burn. I checked with a preview to see how things looked, and it looks good. However, when I actually Encode, the encode simply finishes almost instantly and no target file is found. What am I doing wrong?
    /bin/sh: /Library/Application Support/ffmpegX/mpeg2enc: Malformed Mach-o file
    Sun Jul  6 11:18:38 ADT 2008
       INFO: [yuvscaler] yuvscaler 1.9.0 (15-02-2004) is a general scaling utility for yuv frames
       INFO: [yuvscaler] (C) 2001-2004 Xavier Biquard <xbiquard@free.fr>, yuvscaler -h for help, or man yuvscaler
    movtoy4m
    Copyright 2002-2006 Johan Lindström
    All rights reserved..
    ++ WARN: [yuvscaler] Could not infer norm (PAL/SECAM or NTSC) from input data (frame size=720x480, frame rate=24000:1001 fps)!!
       INFO: [yuvscaler] input:   frame size:  720x480 pixels (518400 bytes)
       INFO: [yuvscaler] input:       chroma:  4:2:0 JPEG/MPEG-1 (interstitial)
       INFO: [yuvscaler] input:   frame rate:  24000/1001 fps (~23.976024)
       INFO: [yuvscaler] input:    interlace:  none/progressive
       INFO: [yuvscaler] input: sample aspect ratio:  1:1
       INFO: [yuvscaler] from 720x480, take 720x480+0+0, NOT_INTERLACED/PROGRESSIVE
       INFO: [yuvscaler] scale to 720x480, 720x480 being displayed
       INFO: [yuvscaler] Scaling uses the RESAMPLE algorithm,
       INFO: [yuvscaler] frame rate: 23.976 fps
       INFO: [yuvscaler] Scaling ratio for width is 1 to 1
       INFO: [yuvscaler] and is 1 to 1 for height
       INFO: [yuvscaler] Specific downscaling routing number 4
    ~Alexius
  2. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    The encoder engine, mpeg2enc, seems broken, hence no encoding is taking place. Try downloading and installing it again. If it still fails, try this copy instead; it seems to have solved it for some users with continuous mpeg2enc problems.
  3. Member Alexius's Avatar
    Jul 2008
    Canada
    That copy seems to have done the trick. Thanks!
    ~Alexius
