I have been using Mpeg Streamclip quite often for the past year and have never had any problems until today. I was trying to convert a VOB (ripped from MTR) to Mpeg with MP2 audio, and, well, it did convert it, but when I tried to open the converted mpeg file in either quicktime or MPEG Streamclip, both applications quit. I opened the converted mpeg in VLC and the video was very garbled.
The original VOB (ripped from MTR) plays fine in VLC, but does not playback as well in MPEG Streamclip, resulting in random blockiness and... how can I describe this... jittery frames? For instance an unmoving object's outline jitters.
The specs of the VOB used are:
Type: VOB program stream
Duration: 0:55:34
Data Size: 1.96 GB
Bit Rate: 5.05 Mbps
Video Tracks:
224 MPEG-2, 720 × 480, 16:9, 29.97 fps, 7.50 Mbps, lower field first
Audio Tracks:
128 AC3 2/0, 48 kHz, 192 kbps
129 AC3 3/2, 48 kHz, 448 kbps
130 AC3 2/0, 48 kHz, 192 kbps
Stream Files:
VTS_03_1.VOB (1023.83 MB)
VTS_03_2.VOB (984.27 MB)
This happens on both of my Mac Mini's, one a 1.25Ghz G4, and the other a 1.66Ghz Dual Core, both running Mac OS X 10.4.11.
Is the bit rate too high for MPEG Streamclip to handle?
Thanks for reading!
-P
Results 1 to 1 of 1
MPEG Streamclip MPEG-TS to MPEG4/H264 (file size & aspect ratio query)
By Heathy65 in forum Video ConversionReplies: 5Last Post: 4th Apr 2012, 12:31 -
MPEG Streamclip / Converted WMV to MPEG-4 but only got the audio? Help me.
By aka_director in forum Video ConversionReplies: 0Last Post: 3rd Oct 2010, 23:24 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 18:12 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 08:30 -
Mpeg Streamclip and Final Cut Pro .mpeg...Only 1 hour clips?
By checksum in forum MacReplies: 10Last Post: 17th Dec 2008, 00:38
