I created a compliant divx movie using Tmpgenc 4.0 Xpress and I tired to use Divx Author to create menus. What I noticed is that Divx Author continues to re-encode the video, which is already a compliant divx file.
Does anyone know a way to avoid the re-encoding part of the process? I would appreciate any information on this subject.![]()
Do unto others....with a vengeance!
This has been mentioned a lot with this product, and I have not seen a way to get around it. However what hasn't been clarified is whether or not it is truly re-encoding, or simply demuxing and remuxing very slowly. I personally have not had a need to try the program out for myself as all my players are standard Divx players, I don't see the need for menus beyond what they provide for me.
As an alternative you might try this : http://labs.divx.com/MenuRaiderRead my blog here.
Thanks Guns1inger for your reply, I have one more observation.
I noticed that the menus do not work in the divx player, the menu pages are visible, yet all selections play the video from the beginning. Has anyone experienced this and if so what suggestions can you give.Do unto others....with a vengeance!
TMPGENC DVD Author Divx - Cannot import .srt subtitle files - how to do it
By wa5dxp in forum Authoring (DVD)Replies: 20Last Post: 26th Oct 2010, 10:45 -
Does divx author reencode Divx and xvid files?
By Onceler2 in forum DVD RippingReplies: 4Last Post: 26th Aug 2008, 18:16 -
Cropping in Divx Convertor or Divx Author???
By rahul.never2far in forum EditingReplies: 9Last Post: 25th Sep 2007, 10:28 -
Help with re-encoding avi files (XviD/DivX)
By noskid21 in forum Newbie / General discussionsReplies: 2Last Post: 18th Aug 2007, 14:24 -
Dr. DivX converts large VOB files into tiny unusable divX files
By texas1 in forum Newbie / General discussionsReplies: 2Last Post: 6th Aug 2007, 21:44
