hi
I have a DVD video that has a game also included.
I can play the game on Window Media Player only.
but when I extract the menu (including the game), the game plays by itself as video so fast that I cannot even click on anything.
How can I extract the game and convert it to flash or whatever so I can play it on my PC without the DVD?
thanks in advance![]()
Is it a standalone game that has its own system of files? Or is it one of those remote based games that you can use on a regular dvd player and just a remote?
If it is remote based I don't know of a way to get the same interactivity on a rip other than to rip the entire disc to the pc (ie dvd shrink, ripit4me, anydvd, etc).
If it is an actual computer game than you can simply install it on to your pc as you would a regular game. Just find the setup file on the dvd in the explorer folder.
I may not be interpreting the type of game you are talking about correctly. If not please offer more desprictions and one of us here might be able to offer you a solution.
AND welcome to the website!Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
I knew you wont understand my english
i am really sorry!
anyhow, thanks for your reply. and it is not a game, just an anime has a game.
I hope this video explains
http://www.zshare.net/video/1479596475021448/
ok, I have tried anydvd which preserve the menu AND at least one chapter from the dvd.
but the question is "how can i just preserve the menu only or just the game if possible?"
The short answer is that you cannot simply extract the game or convert it to flash. What you would have to do it extract all the still and/or video images that make up the game, then work out the rules and re-program it is in actionscript (assuming you want to play it in flash).
You might be able to use VobBlanker or similar to create a very cut down version of the DVD by killing everything else around it, but you would have to start by extracting the entire DVD in the first place and go from there.Read my blog here.
WOOOOOOOOOOOH!!!!!!
thanks a lot guns1inger
that what I was looking for.
I extract the game and I can play it with Media Player. 3 MB
ummm....
just another question ^^"
when I convert it to ISO and play it with Media Player, it doesn't work.
Any suggestion?
thanks anyway
Use VLC, which can play ISOs (although I don't know if it will play a DVD from within an ISO), or mount the ISO with Daemontools, then use WMP.
Read my blog here.
Extract Audio off a game CD
By ranchhand in forum AudioReplies: 9Last Post: 30th Mar 2011, 10:22 -
Extract Video files from DVD
By thumpy in forum Video ConversionReplies: 3Last Post: 21st Apr 2010, 00:37 -
How to extract pictures from a dvd video file?
By tkirby in forum EditingReplies: 3Last Post: 3rd May 2009, 01:46 -
Extract video from DVD
By prl in forum DVD RippingReplies: 8Last Post: 8th Jan 2009, 16:35 -
How to extract video MPEG-2 from DVD?
By fvisagie in forum DVD RippingReplies: 2Last Post: 6th Oct 2008, 11:53
