I have an avi file wherein there is hardsub english subtitles, the problem is the font color of the subtitle use is very dark, very hard to read, I want to change the font color to a lighter color.
Is there a way to change a certain color in an avi video to another color?
For example, the font color used in the video is pink, I want to change all the pink color in my video to yellow.
Please advice any software, plugin that can do this.
Thanks.
You could try ColorMill and VirtualDub: colormill2.1.1.zip It has quite a few color adjustments available. You may be able to change a color without too much affect on the rest of the video. But you will have to re-encode the video, which will give you some quality loss.
A bit more advanced would be a program that used chroma keying or similar. Others would have to give you info on that. It's how a 'green screen' is set up. It can be set for a single color. Most likely you will have that same color you are trying to change somewhere in the video and you may end up with a problem when it shows. -
Had tried the colormill plugin of virtualdub and it does not have the feature I need. The colormill basically controls the color settings of the whole video clip.
What I need is a plugin or tool that can let me specify the original color and final color. For example :
original color : blue
final color : red
So it will change all the blue color in the video clip and change it to color red.
Anybody have other ideas or tips? Thanks. -
Look for some green screen composting software that's flexible enough to let you specify which color is transparent. Then use a solid color background to show through the transparent area.
Here's someone who did something similar with AviSynth: http://forum.doom9.org/archive/index.php/t-56277.html
AviSynth has some color key masking tools too: http://avisynth.org/mediawiki/Internal_filters#Overlay_and_Mask_filters -
CineGobs Keyer might be able to do this as well. Same theory, visual tool.
Read my blog here.
Rendering to x264, Color Change
By Mator in forum EditingReplies: 4Last Post: 28th Mar 2012, 10:25 -
How to change subtitle color in DVDStyler?
By user2008 in forum Authoring (DVD)Replies: 3Last Post: 5th Dec 2010, 08:53 -
How to change background color of my video?
By sanny in forum Newbie / General discussionsReplies: 1Last Post: 22nd Oct 2008, 17:34 -
How to change the color of the taskbar from black.
By mysts in forum ComputerReplies: 2Last Post: 24th Feb 2008, 15:03 -
Change brightness, contrast, color, etc.
By JoeMuskie in forum EditingReplies: 4Last Post: 22nd Oct 2007, 23:26
