Hello, i have a lg vx8350 cell phone, provider is verizon. i recorded some video, and would like to convert it to avi. i have tried a few programs, one is quick media converter. it will accept the video file, will play the file (but has no audio). when i go to do a conversion, it will start then give an error and stop, it doesn't say what the error is. here is the file information from the program for the file on the phone:
General
CompleteName : D:\phone\video\0704082221.3g2
Format : MPEG-4
Format_Profile : 3GPP2 Media
CodecID : 3g2a
FileSize/String : 13.5 MiB
Duration/String : 22mn 30s
OveralBitRate/String : 84.0 Kbps
Encoded_Date : UTC 2008-07-05 02:44:18
Tagged_Date : UTC 2008-07-05 02:44:18
Video
Format : MPEG-4 Visual
Format_Profile : Simple@L1
Format_Settings_BVOP : Yes
Format_Settings_QPel : No
Format_Settings_GMC/String : 0 warppoint1
Format_Settings_Matrix : Default
BitRate_Mode : VBR
BitRate/String : 69.3 Kbps
BitRate_Maximum/String : 570 Kbps
Width/String : 176 pixel3
Height/String : 144 pixel3
DisplayAspectRatio/String : 1.222
FrameRate_Mode : VFR
FrameRate/String : 11.534 fps3
FrameRate_Minimum/String : 0.429 fps1
FrameRate_Maximum/String : 15.000 fps3
Resolution/String : 8 bit3
ScanType/String : Progressive
Bits-(Pixel*Frame) : 0.237
StreamSize/String : 11.2 MiB
Audio
Format : QCELP
BitRate_Mode : CBR
BitRate/String : 14.0 Kbps
Channel(s)/String : 1 / 1 channel1
SamplingRate/String : 8000 Hz
Resolution/String : 16 bit3
StreamSize/String : 2.25 MiB
the other program i have tried is called pazera free 3gp to avi converter. basically the same as above, but when it goes to process the conversion, it also errors and gives a log file that there isn't a supported codec. here is the log file that it gives:
Error # 1
Date & Time: 7/5/2008 / 12:14:41 PM
ExitCode: 1
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'D:\phone\video\0704082221.3g2':
Duration: 00:22:30.7, start: 0.000000, bitrate: 83 kb/s
Stream #0.0(eng): Video: mpeg4, yuv420p, 176x144 [PAR 1:1 DAR 11:9], 15.00 tb(r)
Stream #0.1(eng): Audio: mp4a / 0x6134706D, 8000 Hz, stereo
Output #0, avi, to 'D:\phone\0704082221.avi':
Stream #0.0(eng): Video: wmv2, yuv420p, 176x144 [PAR 1:1 DAR 11:9], q=2-31, 250 kb/s, 15.00 tb(c)
Stream #0.1(eng): Audio: libmp3lame, 44100 Hz, stereo, 64 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
Unsupported codec (id=86043) for input stream #0.1
also the files exstensions for the video files on the phone are .3g2.
thanks in advance.
Results 1 to 9 of 9
If it's an ambulance...you got a chance. If it's a hearse...it's even worse!!!--Judge Alvin "JP" Valkenheiser
Want to extract audio from .vob files? Read my guide at https://www.videohelp.com/forum/viewtopic.php?t=187078 -
you might try emailing the video from the phone to yourself. the carrier will usually convert the weird phone only audio format for you to a usable one. i looked for a while and never came up with a codec that can handle 3g cell phone audio.
Just an fyi I'm sure there is a charge involved in sending this. Make sure you check out your phone contract for rates involving video.Originally Posted by aedipussDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
the audio stream in your phone cam video is QCP format
Quick time will play this with sound
quick time pro 7 will decode and convert the audio stream to mp4 or avi with the correct sound track for your PC
and super might Do it, or DL MPC with quick time alternative plugin -
This turned up recently in the Tools list:Originally Posted by wingnut2003
https://www.videohelp.com/tools/Free_3GP_Video_Converter
Haven't gotten to it yet, but hope it turns out to be a good solution. (I'm using the VX8600.) You can't do much with the cellphone video as it is . . . .Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com -
I believe that program is for converting OTHER formats to 3gp
QT pro is probably the best for converting from 3g to avi or another format
its the qcp AUDIO stream that is the problem, not the video stream.
i have the voyager & the dare, i had the enV, my wife has the 'flipshot' & u740/alias -
Hello ,
I have the explanation why Quick Media Converter is not converting your audio and just converting the video.
Looking at your technical specs , it appears that your original file is using a QCELP audio codec from qualcom ,this is widely discussed on Cocoonsoftware.com forum however the reason it does not work
is simply because it is a proprietary codec (not free) and it is not yet supported by ffmpeg applications. To find a software that would work for this you probably would have to pay for the time being and wait for open source code to come up with a solution .
Have a good day -
Hello,
Thanks for all the help, i have figured it out. I got super to encode the files, the video and audio quality are decent enough for viewing on a computer, didn't expect dazling results. here is a picture of the settings i got to work:
you got it solved, thats good
i would suggest using 352*288 and a 5:4 aspect ratio
I think your picture will be sharper and the image aspect more correct
and your 9600 video bitrate is overkill,1200 is more than enough, likely any thing over 700 is a waste
the source is 15 fps, so use 15 or 30 if you want to keep the sound in sync, that 29.97 will cause a sound sync drift, if you record/covert a long video
Converting Fraps recorded video for Youtube
By mr-scarface in forum Video ConversionReplies: 4Last Post: 2nd Feb 2012, 01:40 -
Coverting recorded TS or MPEG recorded from DVB card to XVid Avi...
By MohamedYousri in forum Newbie / General discussionsReplies: 4Last Post: 7th Nov 2010, 16:38 -
bad quality of camstudio recorded avi video merged by avs video converter
By shimi in forum EditingReplies: 5Last Post: 25th Feb 2010, 16:33 -
Converting DV video recorded with a PAL DV Camcorder
By abouit in forum Newbie / General discussionsReplies: 2Last Post: 13th Sep 2009, 21:21 -
Advice on converting TV recorded .TS to AVI or H.264
By doveman in forum Video ConversionReplies: 8Last Post: 22nd Apr 2009, 10:06
