Hello,
I have a data CD disc that seems to work ok and I seem to be able to access my data fine.
I used Nero CD-DVD Speed to check for errors and it came up with :
I see that I have no C1 Errors and a lot of C2 Errors, but I am still able to access my data, but if the cd works fine how come the program shows that there is errors?
Also every time I check the error count is different
I'd first try a different brand disc. Errors are always there, but small ones shouldn't cause any problems. If a different brand disc shows less errors, then change brands.
What program did you use to burn the disc? Likely makes no difference with a CD data disc, but you could try ImgBurn.
I haven't tried Nero CD-DVD Speed on a CD disc, so I don't know if that error count is excessive or normal. But others here may have some ideas.
Conversion errors in dvd slideshow gui during export burn to disc
By outdoorsyisin in forum Authoring (DVD)Replies: 2Last Post: 16th Mar 2012, 11:29 -
Block errors in video extracted from DVD-RAM disc
By kosdi07 in forum DVD RippingReplies: 0Last Post: 2nd Mar 2012, 15:45 -
need help!!! errors when burning to disc
By bill allert in forum Newbie / General discussionsReplies: 6Last Post: 21st Sep 2011, 16:50 -
Disc Burning Errors HELP!!!
By rocketmastercs in forum Newbie / General discussionsReplies: 5Last Post: 23rd Jul 2008, 00:15 -
What is the Deal w/ Liteon Recorders? Invalid Disc errors?
By peggypwr1 in forum Newbie / General discussionsReplies: 3Last Post: 21st Dec 2007, 22:00
