    Jul 2008
    AVI: Stream 0 (audio) has a non-zero start position of 2 samples (+67
    ms). VirtualDub does not currently support a non-zero start time and the
    stream will be interpreted as starting from zero
    does anyone know a way of fixing this am new it this stuff but 100% hoping to fix this
    any help would be greatly appericited
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Well for starters assuming virtualdub actually can read the audio you can save it as a wav file by using file-save wav and edit it later.
    You can also use virtualdubmod and go to streams and demux just the audio if it is ac3 or dts and you want to preserve it. Then you can remux the audio later.
    Jul 2008
    ok i can do that does it mean i have to start the file 67ms inbewteen
  4. Member yoda313's Avatar
    Jun 2004
    The Animus
    You may have to work with the offset for the audio. Unfortunately I've never fooled around with that as I haven't had a similar audio problem.
    Check the help guides in the "how to" section on the left of the screen for correcting audio synch issues.
