My new PC came with an 'OEM' (= pester regularly for upgrade) version of Cyberlink's Power DVD. On my old PC I had version 5 which allowed me to click in the 'slider bar' to jump to that section of a DVD. Am I right that that's no longer a facility in version 7 please?
LATER:
It seems that this issue only arises when I play the DVD by opening its IFO, when I get a window titled 'DVD Auto-Resume' containing the message:
"This DVD title's playback was interrupted before completion. Where
would you like to start playback?
- Play DVD title from the beginning
- Resume playback from the last scene"
If instead I open the VOB, the click-in-slider-bar feature works OK.
BTW, I tried to send this as a reply to my own post, which IMO would be more logical, but it failed. I read "Please try not to bump your topic(reply to your own topic) immediately, wait at least a few days." That seems an odd rule IMO. I'd have thought it made sense to clarify your own post, or add more information, or even report it sorted, as soon as possible? Editing the original is an OK alternative, but how long does that remain possible?
Terry, East Grinstead, UK
	You can always use a mouse wheel to advance your video in powerdvd.
 And sorry bumping is generally looked down upon on this website. If someone doesn't respond in at least several days than you might consider it. Just be patient and somebody will try to help.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
	Thanks but mouse wheel appears to have no effect here.
 As for 'bumping', I don't think you read my post properly. Rather than being impatient, I think it's considerate to tell people asap that, for example, a problem has been fixed, to minimise the risk of others wasting their time.
	Oh sorry if I misinterperted it. What you can do instead is edit the title of your post so that you can say 'solved' if you figured it out on your own. Or change the title to suit your current issue. Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
	The click-slider in Version 7 works fine for me whatever way the dvd starts or resumes.
 I have a few commercial disks where it does not work (the exception) but I put this down to how they were authored rather than a fault on the player.
	He may have the castrated OEM version like what came on my Dell. So crappy and difficult to live with, I uninstalled it and use Media Player Classic - much easier. ;/ l ,[____], Its a Jeep thing,
 l---L---o||||||o- you wouldn't understand.
 (.)_) (.)_)-----)_) "Only In A Jeep"
  Lacie Cinema: Can't power device on using remote but will power on with USBBy truequant in forum Media Center PC / MediaCentersReplies: 1Last Post: 14th Nov 2011, 04:03
  Avidemux lag after moving the sliderBy las7h0p3 in forum Video ConversionReplies: 2Last Post: 3rd Jun 2009, 11:30
  Anyone know Power Producer (first version?) very well?By gastrof in forum Newbie / General discussionsReplies: 1Last Post: 13th May 2008, 12:37
  Color correction-slider for avisynth ?By SerbianBoss in forum EditingReplies: 24Last Post: 6th Dec 2007, 17:12
  where to download old version of dvd fab??? error in new versionBy willhenderson in forum Newbie / General discussionsReplies: 1Last Post: 1st Dec 2007, 17:00
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
