I have a bunch of homebrew DVDs I made, including some menus, a couple of years ago. But the project files are long gone. They all have MP2 audio, which generally play fine in most DVD players. But we just got a new one that doesn't like the MP2 audio. It works fine with AC3. Is there a reasonably simple way, without having to re-author the DVDs, to just convert the MP2 to AC3, presumably with the same bit rate?
If I extract the MP2 and convert to AC3, can I then use something to just replace the audio in place, within the VOB structure?
Xesdeeni
Hello Xesdeeni,
No. You'll have to reauthor at least the video itself, if not the entire DVD.Is there a reasonably simple way, without having to re-author the DVDs, to just convert the MP2 to AC3, presumably with the same bit rate?
No.If I extract the MP2 and convert to AC3, can I then use something to just replace the audio in place, within the VOB structure?
Demux (PGCDemux), convert the audio (however you were planning on doing that), remux with the new audio (Muxman), stick the remuxed video back into the original DVD using the "Replace" button of VobBlanker. That way you keep the menus and anything else that was in the DVD originally. This is all pretty easy, but may take a bit more time to accomplish than you had hoped. -
No, if I understand what you are saying, that is exactly what I want to do!
But let me be sure I do understand. Once I have a muxed MPG program stream (MPG video + AC3 audio), VobBlanker will let me reconstruct the DVD, right?
I've never used VobBlanker. Is it difficult to figure out how to do this, or is the interface pretty intuitive?
BTW, thanks for the awesome (and quick) answer! Thanks!
Xesdeeni -
Hi,
Easy. Open the original DVD (the one with the MP2 audio) in VobBlanker. Highlight the video in question in the upper screen so it appears in the lower screen. Highlight it in the lower screen and to the right hit the "Replace" button. Scroll to your new DVD with the new audio and hit the VTS_01_0.IFO. Give it an Output Folder and "Process". Here's a guide to doing what you want;I've never used VobBlanker. Is it difficult to figure out how to do this, or is the interface pretty intuitive?
http://www.digital-digest.com/articles/Simplistic_Guide_for_Replacing_DVD_Streams_page1.html
But you'll be able to do it yourself in less time than it takes to watch the damned thing. If you have to, just go through the third part, "Replacing the Muxed Titles into the Original DVD". Also:
You'll have to create a new DVD, one without any menus or anything else. That's why I mentioned Muxman earlier. VobBlanker will require a real DVD for replacing. An MPG isn't good enough.Once I have a muxed MPG program stream (MPG video + AC3 audio)... -
It will, in case you patch GOP headers to 720x480 with DVDPatcher. In the end of its job Muxman gives a warning of 'non-standard' but it doesn't matter. I don't know exactly what VOBBlanker will say afterwards (I once had DVDRemake eaten such files), but there's a chance. In the final DVD VOBs can be patched back to 544x480 for wider player compatibility.Originally Posted by Xesdeeni
Audio duration change after transcoding from MP3 to MP2 or AC3
By darklock in forum AudioReplies: 3Last Post: 24th Feb 2012, 15:50 -
H264 + AC3 + AC3 --> VOB - What is wrong with my command line?
By olik in forum ffmpegX general discussionReplies: 5Last Post: 3rd Feb 2008, 07:06 -
question about VOB file structure on DVD
By jimdagys in forum Newbie / General discussionsReplies: 7Last Post: 11th Jan 2008, 03:58 -
create dvd structure from a .vob
By forare in forum Newbie / General discussionsReplies: 6Last Post: 12th Sep 2007, 03:13 -
Can't convert VOB with AC3 correctly.
By StealthKing in forum DVD RippingReplies: 9Last Post: 13th Aug 2007, 18:32
