I want to cut scenes from some movies I have which come in VOB files.
I also have some MPEGS that I downloaded
So I want to put them on a disc, maybe with a basic menu where I can select the file I want to play on nornal dvd players.
Dont want to change output format or anything, just want to keep quality as it is.
	You have a couple of options.
 Many mainstream dvd authoring apps allow for direct vob imports. You just load the vob and make your dvd how you want to. Tmpgenc Dvd Author is such a program.
 You can also use something like mpg2cut2 for easy editing without reencoding. Than you can take the output and use the authoring program you want.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
  No audio when saving .MPEG file from VOB stream using MPEG Streamclip?By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 18:12
  authoring PAL DVD using "mpeg-4 avc" NTSC 1280x720 VOB filesBy ah76 in forum Authoring (Blu-ray)Replies: 14Last Post: 31st Oct 2009, 10:31
  Using ffmpeg command line to convert a .vob(DVD) to avi/mpegBy alfo666 in forum Newbie / General discussionsReplies: 1Last Post: 13th Sep 2009, 04:14
  DVD/vob/mpeg to Avi/xvid automated process, Help!By sinz in forum Video ConversionReplies: 0Last Post: 14th Apr 2009, 02:08
  How to convert IFO/ Vob to mpeg (sony DVD camcorder)By Guthix in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd May 2007, 19:05
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
