I have installed VM Ware & my OEM XP home edition and everything is ok except the USB support.
My goal:
I want to connect my usb modem to connect on the net with this virtual machine (yeah not the host, this one)
problem:
When i connect my modem, Xp don't regognize it as a "new device" ,nothing so i'm stuck.
Some help is needed vm ware's gurus![]()
At least you gout yours to run. I installed one of our VMware Workstation licenses on my new workstation and it went BSOD, apparently due to something wierd with the USB implementation. Which VMware app are you running?
FB-DIMM are the real cause of global warming -
Not too sure about Server. Fortunately VMware support is pretty quick once you get a ticket started with them.
How to install SimplyBurns a basic and simple burn-ware?
By Bonie81 in forum MacReplies: 3Last Post: 7th Jan 2012, 18:14 -
USB Capture Problem
By sdculp in forum Newbie / General discussionsReplies: 1Last Post: 27th Jan 2009, 15:52 -
problem with usb 2.0
By guitardan in forum ComputerReplies: 3Last Post: 2nd Dec 2008, 11:02 -
Problem with my USB ports...
By nhbfan12345 in forum ComputerReplies: 3Last Post: 6th Oct 2008, 18:15 -
best hardware + s'ware for bulk vhs to file capture & archiving
By miamicanes in forum Capturing and VCRReplies: 3Last Post: 8th Sep 2007, 20:05
