ah 25fps thank you very much for this explanation jagabo!!Originally Posted by jagabo![]()
Results 121 to 128 of 128
By the way, the result of that script is 25 fps interlaced so be sure to encoded to MPEG as interlaced for DVD.
And that script isn't optimal for telecined NTSC video. It's for full 59.94 field per second video (29.97 interlaced frames per second). 45tripp took me to literally when I said your source was interlaced. Your source is telecined so it has a mix of progressive and interlace frames. The best way to convert to PAL, as mentioned earlier is to inverse telecine back to 23.976 fps film frames, then speed it up to 25 fps. -
oh all this seems a bit to difficult for meOriginally Posted by jagabo
...but when I now covert my subtitles so they fit to 25FPS instead of 29.97 then they still aren't synced with my video
...do I have to convert my video to PAL the way you suggest and then my subtitles will work? Or what shall I do
cheers
michcio -
I think you can convert subtitles from PAL<=>NTSC with subtitle workshop. There are presets for input and output FPS
Even easier: You can probably find subs PAL or NTSC subs for any movie just doing a <SEARCH> on a subtitle database
Spend that 5$ to buy the DVD!
yeah I can also change to NTSC with SubtitleCreator but are my .m2v a NTSC still when I have changed all these FPS settings in my script?...but ill try to create a project with these NTSC settings...and yeah I will probably spend some money to buy this DVD instead ... :POriginally Posted by poisondeathray
ty for answering
michcio -
What type of subtitles to you have? After 45tripp's script subs that are time based (like SRT) won't need any conversion because the running time is exactly the same. Subs that are frame number based will need conversion.
well I got these FPS based subtitles...which I have now converted to NTSC subtitles in SubtitleCreator...I made a simpel project in GfD and they worked!!!...I'll now "create my DVD" onse again and see if they work in the "big" project as well...but I think everything will be alright now!
will inform you in about 2-3 h how my project went...(yes it takes so long time to create all my .ifo/.vob and more.... files)
THANKS for all your help!!!...
hope it will work this time
michcio -
ok I have now "created DVD" in my big project as well and my subtitles work perfectly!!! I'll now just shrink all my .m2v a bit and then burn my DVD..I hope it will work in my player as well...
BIG THANKS TO ALL OF YOU!!
michcio
Avi-to-DVD using HCenc?
By eskro in forum Authoring (DVD)Replies: 22Last Post: 2nd Feb 2010, 07:18 -
How to Encode Womble Mpeg Video Wizard projects with HCenc
By tmw in forum User guidesReplies: 18Last Post: 10th Jul 2009, 15:49 -
90% CPU while convertning .avi to .m2v (HCEnc)
By michcio in forum Video ConversionReplies: 4Last Post: 26th Nov 2008, 18:45 -
DGIndexed MPEG or AVI wrapped MPEG best for AVISynth?
By flywitness in forum EditingReplies: 1Last Post: 12th Sep 2008, 10:08 -
Why is my HCenc resulting lighter/brighter AVI video?
By oavs in forum Video ConversionReplies: 16Last Post: 15th Jul 2007, 08:23
