hello!
I have always converted my AVI files with HCEnc and AviSynth. Now I got a video with Dolby ac3 sound and I can't open my .avs file (which I create with FitCD) in HCEnc... I know there has been problem with DOLBY sound and Avisynth but I have not found a solution ... please help how do I solve this problem?!?!?!
Gratefull for answers
michcio
Results 1 to 30 of 128
well you never need to feed audio to hc,
and if it's dolby, you just want to keep it anyway
so:
but just for in case:Code:avisource("movie.avi", false)
ac3 acm decompressor
tripp"I'll give you five dollars if you let me throw a rock at you" -
thank you very much it works now to encode these videos with Dolby sound!!
thank you for solving my problem that fast too
regards and big thanks
michcio -
but hmm now when I try to open this .avs file in VirtualDubMod I can not see the audio stream when I klick on streams--> streams list...why is it gone? please help!
avisource("movie.avi", false)Originally Posted by michcio
The "false" means don't include the audio. Demux the AC3 audio track (open the AVI with VirtulDubMod, go to Streams-> Stream list, Demux) and add it manually after opening the AVS script. Or use VirtualDub and its "Audio from another file" option to read the AC3 from the AVI. -
ah cool the demuxed audio works perfectly with the .mpeg file thanks!!!
(I just needed to split on them both)
yeah I added false...but DirectShowSource() instead AviSourse() doesn't work...HCEnc freezes every time I try to open with DirectShow...but as said it work fine with false
If you want to use DirectShowSource (why?), and want to disable the audio, you have to use Audio=False, instead of the simple False if using AviSource.
Always test your scripts in VDub(Mod) before sending to the encoder. It often gives a better error message that might help pinpoint the problem.
http://avisynth.org/mediawiki/DirectShowSource -
I don't want to use DirectShowSource...but when I use it (without false) and open my script in HCEnc then the program freezes. But never mind it works with "normal" code (AVISource) + false.
HCEnc doesn't encode audio, so there is no benefit to sending the audio through anyway. You know it works when you set audio to false, so set it to false and get working.
When you have time, try using MediaInfo on the avi file in question and confirm exactly what audio compression the file has. I suspect it isn't AC3Read my blog here.
ah to see exactly what audiofile my avi file has I use GSpot. So when I mean dolby it's actually : 0x2000 (Dolby AC3) AC3...
I got a problem with this dolby sound again...I want to create a .m2v file and one .ac3 with the .m2v's audio (from a .avi file)...I have tested to encode the .avi file without audio in HCEnc and I got a .m2v file as result...Then I have opened my .avi file in VirtualDubMod and demuxed my audio (saved the .ac3 file)
but now when I open my .m2v togheter with my .ac3 file in MediaPlayerClassic they are not synhronised...why is that??? please help!
where do I see this in MediaInfo? when I open my .avi file in MediaInfo I just see this information about my audio stream:
Code:First audio stream: 224 Kbps, 48.0 KHz, 2 Channels, AC-3
In mediainfo use view=>text for more detailed information. The basic view doens't give all the info. It will look like this (for the audio part). The delay is at the bottom
Audio
Format : AC-3
Format/Info : Audio Coding 3
Format profile : Dolby Digital
Duration : 15s 616ms
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : 2 channels
Channel positions : L R
Sampling rate : 48.0 KHz
Video delay : -8ms -
well the audio seems to be fine in the beginning but when I look in the middle of the movie it's completly wrong!Originally Posted by jagabo
here's my audio in "tree mode" then:Originally Posted by jagabo
hope this information helps you to understand my problemCode:Audio Format: AC-3 Format/Info: Audio Coding 3 Codec ID: 2000 Duration 1 h 29 min Bit rate mode : Constant Bit rate : 224 Kbps Channel(s) : 2 channels Channel positions : L R Sampling rate : 48.0 KHz Stream size: 144 MiB (21%) Aligment: Aligned on interleaves Interleave, duration: 96 ms (2,40 video frames) Interleave, preload duration: 96 ms
cheers
michcio -
the .avis framerate is 25.000 FPS but where do I see which framerate I encode with in HCEnc ??
DirectShowSource("D:\Filmer\croupier\Croupier.avi" ,fps=25,audio=false)
DirectShowSource("D:\Filmer\croupier\Croupier.avi" ,fps=25,ConvertFps=true,audio=false)
hm when I write:
instead ... HCEnc freezes everytime I try to open my .avs file -
But what the... ... it seams like my MediaPlayerClassic is broken because when I open a .m2v file (not with dolby sound and which I have encoded correclty I am sure I have!!) and open it with the .ac3 file which I have created in a right way as well... then the audio and video aren't synhronised at all....it's like with the croupier video...at first they are perfectly synhronised but when I try to rewind a bit the video freezes a bit and then is no longer synhronised....aren't there any other tools for opening the video file and the audio file to see if they are good synhronised?!?!?!
or hm...I have now tried to open my .m2v / .ac3 in windows movie maker and I still have the same problem...the audio is perfect in the beginning but just when I forward the movie the audio/video isn't synhronised anymore :S
I'll now try to create a simple DVD with this .m2v file
ok so I have now created a simple DVD-project wioth one of thoes movies that didn't work in MediaPlayerClassic and they worked perfectly when I "showed the DVD" in GUI for dvd author (also with MediaPlayerClassic)...maybe MediaPlayerClassic was always that way and I have just not noticed it :S
but please help me if you can!
Avi-to-DVD using HCenc?
By eskro in forum Authoring (DVD)Replies: 22Last Post: 2nd Feb 2010, 06:18 -
How to Encode Womble Mpeg Video Wizard projects with HCenc
By tmw in forum User guidesReplies: 18Last Post: 10th Jul 2009, 14:49 -
90% CPU while convertning .avi to .m2v (HCEnc)
By michcio in forum Video ConversionReplies: 4Last Post: 26th Nov 2008, 17:45 -
DGIndexed MPEG or AVI wrapped MPEG best for AVISynth?
By flywitness in forum EditingReplies: 1Last Post: 12th Sep 2008, 09:08 -
Why is my HCenc resulting lighter/brighter AVI video?
By oavs in forum Video ConversionReplies: 16Last Post: 15th Jul 2007, 07:23
