To edit a DVD specially language menu I must add "persian: or "farsi" in the list of subtitle
my question is how can i write the word persian or farsi just with the font of other names in the language menu
I mean there is words English or Spanish for subtitles
I wanna use the font of them
I hope u got the point
thanks ...
To use the same font you would have to have access to it. If it is a custom font or commercial font then you probably won't have it on your system, so you will either have to find a font that is close at somewhere like dafont.com, or buy a license for the one they have used.
I assume you have already added the required subtitles to the disc ?Read my blog here.
Thank uOriginally Posted by guns1inger
but I don't think it can be done by using fonts that are close to it when there id some shadows & everything
there must be a way to use exactly that font ...
How to remove the language selection menu from BR Disc
By The-One in forum Authoring (Blu-ray)Replies: 21Last Post: 27th Apr 2014, 17:00 -
How to bypass the language menu?
By The-One in forum Blu-ray RippingReplies: 1Last Post: 22nd Feb 2011, 05:21 -
Authoring Multiple Language DVD with multiple language menu options
By kemimich in forum Authoring (DVD)Replies: 7Last Post: 8th Sep 2008, 17:29 -
Add a language menu to a DVD
By hellbound in forum EditingReplies: 0Last Post: 6th Aug 2008, 11:01 -
Edit language ID in vobsub
By newnews in forum SubtitleReplies: 0Last Post: 29th Apr 2008, 18:03
