If i have a divx dvd player,do i still need to use a program like convertxtodvd to burn the movie?if not, how do i burn the the movie or avi or divx file to a blank disc? thanks
	just burn it as a data disc. The player will find the files.
	Yes, you can use RW media. If you have Nero Burning Rom elect to make a DVD-ROM ISO. Drag your files to the compilation window. Burn.
	The AutoGK tutorial explains the process for burning to CD. Burning to DVD is the same, but you set Nero to burn a DVD instead:
 http://www.autogk.me.uk/modules.php?name=TutorialEN#7
	I use Roxio 8 and just burn as a data disk. Works great. Haven't had a coaster yet.
  My DivX DVD Player can't play my avi DivX/xvid videoBy Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11
  Need codes to convert Australian DVD player into a multi region DVD playerBy Seajacb123 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 13th Oct 2010, 02:00
  How do convert Divx files to play on my DVD player?By Solehawk in forum Authoring (DVD)Replies: 1Last Post: 29th Jan 2010, 20:37
  How Can I Convert Real Player Video Files To Make Them DVD Player CompatablBy Lennoxtown in forum Video ConversionReplies: 8Last Post: 17th Oct 2007, 07:05
  Hack to convert USB/DIVX DVD player to read from the NetworkBy thrutnut in forum DVD & Blu-ray PlayersReplies: 8Last Post: 21st May 2007, 12:27
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
