    Jul 2003
    michigan
    I have been using tmpgenc video encorder for quite a while. Recently, I decided to try cce sp. My question is how do you load a mpg into cce, since it only recognizes avis. I know cce can be used with dvdrebuilder, to reencode vob files, so there must be a trick to it. Do I need to use avisynth? Or is there some other method? I use Fulcilives method for changing a pal to ntsc, the method works great(thank you Fulci) but, would really like to try it with cce.
    member since 1843
  2. Member driguy's Avatar
    Feb 2007
    Use VirtualDubMod and then frameserve the Mpeg to CCE.
    Don't know how to frameserve?
    In the VirtuaDubMod folder there will be a file called "Auxsetup.exe". There will be a button that says "Install Handler".
    Install the Handler. Open VirtualDubMod then open the MPEG you wish to frameserve...
    Let VDM load the video. Then when the video is loaded, go to File->Start Frame Server.
    Save the .vdr file somewhere. This is like a "dummy file" you serve to CCE.
    Bring up CCE and drag/drop the .vdr file into the window, this should give you the option to encode it.
  3. Banned
    Freedonia
    Alternate method of frame serving MPGs to CCE. I do this all the time. I'm not saying it's better than driguy's suggestion, just another way to do it.
    1) Open the MPG file in DVD2AVI. Do a "Save Project" (F4) and get a *.d2v file created.
    2) Open the *.d2v file in VFAPI and do the "convert" option.
    3) Feed the converted file from step 2 to CCE.
    Jul 2003
    michigan
    thank you both for the info.
    member since 1843
    Dec 2004
    Triptonia
    as shown above, no,
    but as not mentioned you should, with dgindex/dgmpgdec
    tripp
    "I'll give you five dollars if you let me throw a rock at you"
