  1. Member Moonstomp's Avatar
    Oct 2003
    Dublin, Ireland.
    Hi,
    Could someone suggest a website design software that's not too complex and can acieve decent looking results. I'm looking for something that can be learnt quickly.
    Is there anything open-source that would do the job?
    Many thanks,
    Moonstomp.
    Just because you're nobody, doesn't mean that you're no good. Just because there's a reason, doesn't mean it's understood. It doesn't make it all right ! (The Specials)
    Feb 2004
    Australia
  3. Member Moonstomp's Avatar
    Oct 2003
    Dublin, Ireland.
    Thanks Bjs.
    I'll check that out, but it certainly looks like it fits the bill.
    Thanks from Ireland!
    Moonstomp.
    Web Easy Pro is another one that is easy to you yet it is very flexible with what you can do with it.
    http://www.avanquest.com/USA/pc-tools/multimedia/web/Web_Easy_Professional_7.html
  5. Member Moonstomp's Avatar
    Oct 2003
    Dublin, Ireland.
    Thanks SCDVD !
    You guys have been a great help - and very quick to reply!!
    Long live videohelp.com !!!!
    Moonstomp.
    Apr 2003
    Here's yet another one: WYSIWYG Web Builder 5
    http://www.wysiwygwebbuilder.com/
    Brainiac
  7. Member GMaq's Avatar
    Mar 2004
    Canada
    Hello,
    Kompozer, which is the before mentioned NVU with community driven bugfixes, is also good, free, open-source and cross-platform.
    http://www.kompozer.net/
