  1. I would like to add additional chapters to an existing DVD-R a friend made for us. the options on the (original) disc are play movie, scene selection, and photos. How might I add a couple more scenes to the existing selection with redoing the menu from scratch (I usually use TDA for menu creation)? I do not mind re-encoding if it is necessary.
    Thanks.
  3. thanks Baldrick. any freeware solution??
    thanks again.
    Oct 2006
    Canada
    There is a PgcEdit(free). If you want to add anything to a menu you will have to create a new one or modify existing one with new text and highlights, than exchange the old one with it.
    Commands for new buttons can be than edited in PgcEdit or DVDRemake.
    Splitting the title for additional scenes can be also done in both editors.
  5. thanks tinker.
