    Feb 2002
    hi
    i downloaded a film from kazaa,i have encoded part one and put it onto a vcd,but when i came to do the same for part 2,it says and i quote:cannot open or unsupported,which is strange as i did part one.
    can any one shed light on this.
    go on give a newbie a chance
    can you play it with media player?
  3. If the movie will play in media player try this:
    Open TMPGenc
    Goto Options,
    Environmental settings,
    VFAPI plug in,
    Set "direct show multimedia file reader" to priority 5 by right clicking on it.
    This worked for me when I got "cannot open or unsupported" error.
    Let me know how you got on.
    Good luck.
    Bully74uk
    Feb 2002
    Open TMPGenc
    Goto Options,
    VFAPI plug in,
    Good luck.
    does not work,every avi i download,i always gtet the same answer,cannot open or not supported,i have managed to do one,but how i dont know,please somebody help
    Bully74uk
    Feb 2002
    San Antonio, TX
    Don't waste your time.
    Tip one for downlloaded files: CHECK EVERY FILE. Open in virtualdub and play the file to the end. If the file comes up with an error then you have a frozen frame.
    This happens more than you think. almost all video I download has a frozen frame(s).
    If it does, download the avidefreeze(divxdefreeze) program from tools on this website and read the tutoral then fix the frame(s) then encode.
    Problem solved
    By the way if anyone else is listening this is why TMPGenc is not responding in the task manager.
    I figured this out with all 2 weeks of my converting experiance so pass it along to all that you can reach.
    I say this sarcaticly because I see posting all over on this issue and no one has an answer just try this, try that, or my favorite answering you with a question. 10:1 it a frozen frame.
    Sorry for venting on your thread.
