Results 1 to 11 of 11
    May 2006
    All of a sudden I can't download files. I tried to download image burn and one other tool. Both times I get a message that my "Security Zone Policy" won't allow the download. This is new. Happens both in IE and Firefox. Must be an XP setting? Anyone know what is happening?
  2. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    Same EXACT message in both?
    Thats very odd. What kind of Security software are you running?
    Have you scanned for baddies lately?
  3. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    sounds like a false positive from Zone alarm. what version of firefox are you using?
    May 2006
    I'm using Firefox 3.0
    It does not download in IE either.
    I'm not using Zonealarm
    Just windows firewall.
    problems just started since I downloaded Firefox 3.0, but I don't know.
    I using Norton.
    May 2006
    Also, my Windows XP update has been locked at 66% for the past two days. It got 66% into the download and them locked!
  6. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    May 2006
    http://support.mozilla.com/tiki-view_forum_thread.php?comments_parentId=79493&forumId=1
    Seems to be a Firefox 3 problem. I have not found a simple fix yet. People are reloading that I no longer have and can't download. Catch 22. I will get it in time. I just can't download an .exe file until I find a fix!
    Sep 2006
    Any other .exe problems? Had a virus that effected .exe files. Have you tried a system restore to a previous date?
    May 2006
    I found the problem and have a fix. (First one on the internet right here on VH.)
    When you download FireFox 3.0 be sure that IE Zones are set to default levels. In IE, goto Tools: Internet Options; Security - and "Reset Zones to Default Levels". That puts the sliding bar in about the middle. If your Zones were set at "High", like mine were you will have this problem. Mine were set at high because I don't even use IE at all ever.
    Microsoft does not even recognize microsoft.com when the level is set at "High". Try it and see for yourself. Set the level at "High" and try and do a Windows update. It won't work. Windows sees microsoft.com as a suspicious site just like it see's FF3.0.
    I am now able to download *.exe files again in IE. Next I will reload FireFox 3.0 if required.
  10. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    Which is why I uninstalled Firefox 3.0 when it was first released. First time I installed it I got a msg saying AVG 8.0 isn't compatible or something. I uninstalled AVG 8.0 the other day since it's a memory hog. That's why I had such long loading times for my pc and with hotmail. I haven't tried Firefox 3.0 again. I'm still using the last 2.0.0.14 version.
  11. Banned
    Aug 2002
    beautiful
    at zone level high you have everything disabled - including activex, so obviously "microsoft" does not "recognize" its own windows update page since it is based on activex. At such level you can only view simplest pure html pages (good luck finding any like that nowadays).
    It is not a problem with windows or IE or FF per se - it is actually very *proper* and expected behaviour (of Windows with IE).
    When you were setting zone level to the maximum 'protection' (high) you should have read what it actually means and how it affect entire OS environment. Perhaps MS is to blame for not adding some pop-up warning, but it still doesnt release user from educating themselves before they do crucial changes to their OS' settings.
    The only problem here was user, as usually (nothing personal videobread or picking at you - just stating the facts, because really most of the time I help people the problem usually was caused by their indolence or lack of knowledge or misinformation).
    OTOH I wish Msoft would ditch those stupid zones once and for all.
    It drags with windozes since IE4 introduction and even though at first I also thought it was good idea I have very quickly learned it is not - because it is only a reminiscence, just a 'byproduct' of IE4's integration into OS that happened since Win98. IE can work perfectly as standalone app, all windowses were countless times proven to work perfectly fine without any IE either (despite what MS says), so whom are they fooling... the worst part of it is that zones work only with IE while affecting entire OS when non-default browsing-related software is used (I didn't say "browsers" because zones affect many aspects not just the web browsers - networked resources etc)
