All right. I've got a dual audio .AVI (Xvid) video file and an .idx and .sub file I want to add to it. I do not want to hard-code the subs or convert them to regular .txt or.srt files. I want to be able to turn them on or off during video playback in VLC media player. I already know they work separated with the exact file names.
I don't care if I have to re-encode the video in .divx or .xvid as long as it doesn't greatly reduce the video quality. For two days, I've searched for a way to simply merge them together either by re-encoding the video or some other method.
Can ya help me?
Please change the topic subject so it better describes your problem. Just click on the edit-button to change it.
You can make an avi with embedded subtitles using avimuxgui but the subtitles doesn't work in vlc media player.
So I guess you have to make a mkv with embedded subtitles if you want ONE file. Use mkvtoolnix, you don't have to reconvert the video.
edit: See http://www.videolan.org/doc/play-howto/en/ch03.html#id306989 -
Your question isn't really clear to me.Originally Posted by NextJinGamer
Do you just want to turn them off/on and switch languages? If so just right click and access the subtitles options (you can switch languages, turn off, etc...). You can do this "on the fly" during playback
or, did you want to place all 3 files (.avi, txt, and .srt) into 1 container? If so, then do what Baldrick suggested and use mkvmergegui to put everything you want into an .mkv container. No re-encoding.
I guess I'm confused by what "merge them together" means -
Thanks, I'll try what Baldrick suggested. I wanted to create an .avi with multiple audio and subtitle tracks.
Oh yeah, there's one more thing I've been meaning to ask you guys. Is it possible to convert .idx/.sub to .srt with the same fonts, colors and / or images?
Dual or Multi Audio AVI with subtitles (MPEG4 XviD DivX)
By DereX888 in forum User guidesReplies: 16Last Post: 20th Dec 2012, 16:24 -
ffmpegX - idx/sub subtitles lost in converting from avi to Xvid or DivX
By bonespur in forum MacReplies: 5Last Post: 4th Mar 2011, 03:25 -
How to add .sub/.idx to avi?
By gOdiSOnyOuRsIDe in forum SubtitleReplies: 2Last Post: 12th Jul 2009, 13:10 -
avi or xvid file with switchable subtitle to dvd 5
By lovemychemical in forum SubtitleReplies: 3Last Post: 16th Jul 2007, 10:28 -
AVI,DivX,XviD to DVD with switchable subs using DVD2SVCD
By Baldrick in forum User guidesReplies: 18Last Post: 6th Jul 2007, 17:08
