  1. I just bought a lite-on ltd-163 dvd drive and i tried to connect it but when i started windows, it froze and i got the blue screen with an error. Before i connected my dvd drive i had decided to put it on my secondary ide cable in place of my cd-rom drive. The cd-rom was on drive 0 on the ide cable. The other connection, drive 1, is a cd-rw. The cd-rom and cd-rw had jumper settings of cs. When i installed the dvd drive i set its jumper for master and changed the cd-rw to slave. I plugged the same power cable and audio cable that was being used for the cd-rom into the dvd drive. When i started my computer it seemed fine until the windows 98 logo appeared to load windows. It froze and gave me the message. I had to restart and the only way i could get into windows was to go into safe mode. In ordfer to get online i had to disconnect the dvd drive so i could boot up normally. Right now i have it disconnected and now my cd-rw does not show up as available in my computer but it is still connected. What did i do wrong? Any help would be great.
    The error was: "An exception 0E has occured at 0028:00000009 in VxD---. This was called from 0028:C188E197 in VxD---."
    I am running windows 98 SE
  2. this probably won't help but if you want to make cd2cd copies you should'nt put both drive on the same cable.
  3. Would it be better if i put the dvd drive on the cable with my hard drive and set it to slave and leave the cdrom where ti is? Also, I have the audio out from the dvd drive going to the audio in on my sound card, is this ok. I also wanted to know if I had to have a dvd decoder card in order for it to work?
  4. to have your dvd working you'll need a dvd decoder but check your video card alot of the new ones actually have a decoder included. yes it might be better to hook your dvd to the hard drive (leave the audio it's fine) you want to keep your cdrw off a cable you'll probably use to burn (you lose speed that way).
