Where I work I am connected to out network..but here lately the City I live in has put up free internet wwireless connection..how can I get my laptop to connect to the free one wirelessly?..thanks for any help
With some laptops you have to enable the wireless adapter by physically turning it on (look for a button or check your manual)
In XP then you would: start button => connect to => wireless network connection -
Just to add, when you get to the wireless network connection, you should see all available wireless networks, and whether they are open for you to access. If you can't get into any open ones, you may have to check your wireless adapter settings. If it's set for DHCP (Dynamic Host Configuration Protocol) automatically, it should see them all.
Vista can be a little harder to set up, but there are 'wizards' and plenty of help for networking problems built into most operating systems. JMO, but I would be careful not to store passwords, bank or other sensitive info on a computer that will access unknown networks. I would also advise not to do banking or other financial transactions over that type of network most times. At least until you are sure you have a secure connection.
Two internet connections on same PC
By sohaibrazzaq in forum ComputerReplies: 4Last Post: 2nd Jul 2009, 11:17 -
My Computer and internet connections
By CANADASFINEST1 in forum ProgrammingReplies: 1Last Post: 28th Nov 2008, 11:24 -
HD connections?
By James in HD in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 13th Nov 2007, 18:02 -
Kaspersky Internet Security 7.0 installation Conflicting with Internet Exp
By Krelmaneck in forum ComputerReplies: 2Last Post: 5th Oct 2007, 04:36 -
routers and multiple internet connections
By illyad in forum ComputerReplies: 5Last Post: 3rd Jun 2007, 14:27
