When i convert a movie using convertxtodvd, the entire movie does not fit in the screen, for example at the beginning of a movie when you see the credits(the names of the actors)the names do not show entirely on the screen,only parts of them,the other parts run off to the left or right.
What is the original source? Have you tried using the "Set video parameters" and do a "User-defined" resize in ConvertXToDVD? If that doesn't give you the results you want, you may want to use Avisynth in conjunction with FitCD to place overscan borders on the rendered DVD files.
sync problem with Convertxtodvd
By konig in forum Authoring (DVD)Replies: 1Last Post: 7th Mar 2010, 19:55 -
ConvertXtoDVD Problem
By natty in forum Newbie / General discussionsReplies: 24Last Post: 17th Feb 2010, 21:06 -
By natty in forum Newbie / General discussionsReplies: 3Last Post: 1st Aug 2009, 14:21 -
Convertxtodvd problem.
By lameyouth in forum DVD RippingReplies: 1Last Post: 30th Dec 2008, 15:38 -
Problem with ConvertXtoDVD
By konzine in forum Newbie / General discussionsReplies: 3Last Post: 12th May 2007, 22:50
