    Jul 2005
    Canada
    Hello,
    I have used CopytoDVD for a long time but since I have re-installed it (rebuilt my pc) It wont burn for me. I start with using DVD Shrink and then load the VIDEO_TS file in CopytoDVD but when doing so, it will say that its only able to burn to cd (I have the full version) on the left side Project Details (Media: CDR 74 (657mb)) and at the top it shows my dvd burner and beside it it says CDR 74. When it does give me the option for buring to dvd, it continues to tell me to insert a media large enough to fit (which I have a dvd large enough for the movie).
    I have also tried to burn from an ISO file and it too ends up having the same issue. I am unable to figure out what could be causing this, I have tried uninstalling and re-installing but it continues to do the same thing.
    Apr 2004
    Miskatonic U
    Try using Imgburn. If the problem persists, it is your burner. Try uninstalling the burner, then reboot you machine and let windows reinstall it.
    Read my blog here.
