I recently finished a wedding video, and have put it on DVD. Unfortunately,
there is flickering around any objects on screen that have a pattern to
it , as well as in other places to a lesser extent.
Workflow
Export HDV lagrith lossless file from Premiere,
Downconvert via Lancoz3 and Sharpen in Vdub ,
Encode in Hcenc,
Burn in Encore.
I have used this method with 24p and 60i footage on past projects, without problems.
I have tried different mpeg encoders, different codecs, different versions of Vdub.
If I deinterlace, there is no flickering, which causes me to believe that Vdub is messing up the fields, because it is a 30p file. But there are no interlacing artifacts. I've tried switching field orders, which seems to double the problem.
I am using the Canon HV30 which uses a m2t codec, and is true 30p.
http://files.filefront.com/Hcenc+Encodezip/;108681
Here are the files in the three different stages, HD file, Vdub downconvert, and Hcenc Encoded (very short to keep file size down, let me know if you would like longer clips). I recommend burning the Hcenc Encoded to a DVD to watch on a TV, as it seems to be more obvious than on a computer.
Results 1 to 1 of 1
Video is Flickering on Burned DVD
By Peter_B in forum Authoring (DVD)Replies: 3Last Post: 16th Jun 2010, 17:15 -
Title Flickering from MVW-DVD
By cyberboy in forum EditingReplies: 2Last Post: 29th May 2009, 13:30 -
recording from VHS to DVD - picture flickering.
By glen_s in forum DVD & Blu-ray RecordersReplies: 3Last Post: 15th Jun 2008, 11:23 -
vcd playback - flickering picture on one dvd player, fine on another
By i_ming in forum Newbie / General discussionsReplies: 5Last Post: 21st Oct 2007, 08:41 -
Flickering of DVD
By markannab in forum Authoring (DVD)Replies: 2Last Post: 30th May 2007, 19:01
