I need a device that will convert video from another source (probably VGA but I can make other conversions if necessary) to composite or s-video. My main concern is that widescreen sources will come out as vertically stretched. Is there a converter that can output composite or s-video that can switch to a letterbox mode and output these images in their proper proportions?
Results 1 to 9 of 9
I should clarify that the original source is 480p widescreen, with some sources as 480i 4:3. The source will be component video output. I've found a converter from component to VGA that accepts 480i or 480p.
Thus, the chain is component (variable between 16:9 and 4:3)... to VGA (unless a conversion to another format might exist)... to composite or s-video.
As far as I know, there is no simple conversion from component to composite or S-video if the component connection might have 480p sources. Please let me know if I'm wrong. -
It would even be fine if the device had a function for vertical scaling. At work, we have the Grandtec PC to Video Component, and I just discovered that it has such a function. For my purposes, however, I need more vertical squishing than it can do... it is somewhat limited. If any converter had vertical/horizontal adjustments so that I could make a near-16:9 ratio, I would be completely happy.
Why is VGA in the loop?
What are you trying to accomplish?
What is your display?Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
VGA is in the loop because I can't find any solution to converting 480p to composite/s-video without first converting to VGA. 480p capture apparently doesn't exist.
The ultimate accomplishment is to stream video games while still playing them on my TV. Thus, the "display" is the broadcast window in my browser, which is taken in by a common USB capture device. -
Do I have this right?
You want to play games at 480p and real time capture 480p to a computer and also stream live to the internet? Stream in what format?Recommends: Kiva.org - Loans that change lives.
I currently use Justin.tv for live streaming. I don't have a USB capture device yet.
I realize I am going to have to split my component cable using a powered device to avoid loss of quality on my TV set.
I don't care about capturing the video, just streaming. Thus, the video will probably have to end up as 480i (as far as I can tell). Since stream quality is only so high, I'm not overly concerned with what the image looks like by the time it gets to my computer. What DOES matter is that it looks just as good on my TV as it always has. -
480p capture is expensive currently. $400 up and your computer probably isn't fast enough for real time progressive conversion to a stream. Maybe others have an idea.
480i has many capture options also streaming software support.Recommends: Kiva.org - Loans that change lives.
Dvd player plays widescreen dvds in fullscreen on widescreen tv
By Fireworks_at_Dawn in forum Newbie / General discussionsReplies: 35Last Post: 24th Sep 2012, 09:24 -
Canopus AceDVio composite capture problem (Svid works, but not composite)
By bfrandse in forum Capturing and VCRReplies: 3Last Post: 28th Oct 2008, 11:55 -
Composite IN vs S-Video IN (using converter wire composite to s-video)
By goal in forum Capturing and VCRReplies: 2Last Post: 29th Mar 2008, 22:19 -
SCART to S-Video or Composite converter drops color
By chupacabra in forum Capturing and VCRReplies: 28Last Post: 2nd Nov 2007, 18:32 -
Converter: RCA composite into RGBs RPTV
By iMPULSZE in forum Newbie / General discussionsReplies: 1Last Post: 1st Jul 2007, 12:24
