after i have converted the MKV file to MPEG-2 using FAVC. the graphics are great, and a imgburn screen comes up. is that what FAVC uses to burn its videos onto dvd. furthermore, if i wanted to use Nero to burn the new MPEG-2 video onto dvd, would it decrease the graphics of the MPEG-2 video.
Read my blog here.
the problem i have is i havent figured out how to create a menu that i like with imgburn. plus, if imgburn is able to combine the segments of the video into one. and one more thing, when i was using favc at the beginning, am i able to choose not to have any chapters, the default is 5 minute. example, for a video thats 1 hour and 6 minutes, it was split up into 4 parts.
but thank you so much for all your help though. i just i just need to tinker with it a bit more.
Imgburn just burns. That is all it does.
What segments ? Is the source multiple avi files ?
NeroVision will mostly likely re-encode your video and reduce the quality. If you want to create menus etc, then in FAVC make sure you have ticked No for Open Imgburn, and Keep under Working Files.
When FAVC finished, you can use GUIForDVDAuthor on the files created in the temporary folder to author a new DVD with your own menus and chapter stops, and delete the one that FAVC created.Read my blog here.
if i use GUIForDVDAuthor to create the menu, i can use this same program to burn the video onto the dvd, or do i have to revert back to using Imgburn.
sorry, i know this is a dumb question, but i just want to get all my questions sorted before i start using the program.
Trouble transferring VOB to Mpeg
By Idlehanz in forum Newbie / General discussionsReplies: 8Last Post: 12th Aug 2009, 04:09 -
FAVC multi file menu
By win993 in forum Authoring (DVD)Replies: 2Last Post: 29th Sep 2008, 03:08 -
want to convert 8GB mkv file to 2 DVD5's with FAVC
By mr-scarface in forum Video ConversionReplies: 8Last Post: 11th Aug 2008, 10:06 -
FAVC log file
By marioval in forum Authoring (DVD)Replies: 3Last Post: 31st Jan 2008, 07:17 -
WMV to DVD conersion
By uniks in forum Newbie / General discussionsReplies: 6Last Post: 31st Aug 2007, 08:25
