For MKV files, do the videos that are inside them sometimes have a ".H264" (Example: Myvideo.h264)? This is for an application I am writting and I cannot remember if this was the case (4 letters in the extension) as I cannot find one on the internet at the moment.
Also, if anyone knows of an MKV like this please post the link or shoot me a pm for testing purposes.
Also, have there every been any issues with MKVExtract trying to extract these kinds of files? I never extract video, so I am not sure.
mkv I believe is a container just like avi. It can pretty much hold any video type. As for the other questions I'm sorry I don't use mkv.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
"myvideo.h.264" would be the raw video stream using h.264 codec which is inside the .mkv container.
The .mkv container can contain multiple streams of audio, subtitles, attachements, etc...
mkvextractgui can usually extract the raw streams without problems, but sometimes the file is corrupted and it would then have problems
You can't do very much with a raw video stream. It needs to be in a container for you to view, edit or process it using most programs
Here is a sample h.264/aac .mkv from the ironman apple movie trailer
Cheers
ironman.mkv -
Thanks for the response.
I have been working with MKV files for quite a while. I remember on occassion seeing a ".h264" extension. However, I never ever extract video and audio, I just get Subs and let FFMPeg get the audio.
With the app I am writing, I have to think about all of the things I never do but others might.
I was thinking about excluding the ".h264" extension from being extracted, but I may just keep it in. -
If you do extract raw h264 then you can put it in an avi container using
avc2avi
Syntax: avc2avi [options] [ -i input.h264 ] [ -o output.avi ]Donadagohvi (Cherokee for "Until we meet again")
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
MPC-HC, MKV and memory problem
By Docoptik in forum Software PlayingReplies: 7Last Post: 18th Mar 2012, 21:40 -
Memory upgrade question
By zzyzzx in forum ComputerReplies: 12Last Post: 13th Jan 2011, 17:27 -
Question about Installing Memory to my MotherBoard
By hellfire45 in forum ComputerReplies: 7Last Post: 24th Sep 2010, 22:06 -
mkv question... many mkv files (with subs) into 1 mkv?
By 0okami in forum EditingReplies: 1Last Post: 24th Oct 2009, 00:45
