yeah I'm sure I have tested 3 times and as you said in a new folder where I had nothing but just my .srt file ... as before just the .sup file is created... but nevermind it works for me with the DVDSubEditor. If you don't have the energy to help me with this paticiular problem anymore it's OK...
Results 31 to 60 of 71
Originally Posted by michcio
You can check the menu cells in ifoedit:
Load the Video_ts.ifo in ifoedit.
Open the VMGM_PGCI_UT (click on the [+])
You should see a PGC-Menu entry for each menu (MainMenu and MainSubMenus)
If you click on one entry you can see the 'content' in the lower window. Scroll down and check if a line with
Code:1.Post Command (LinkCN) Link Cell 1
GUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
Thank you for your response borax!
Originally Posted by borax
but then I don't see a PGC-Menu for EACH menu (like you said MainMenu and SubMenus) there is just one PGC 'file' named : "LU_1 (English) PGC-Menu_1"...if I click on this 'file' I get many lines in the lower window where I can see:
Adress (begins at 00000002)
Description
Value (dec) and Value (hex)
What am I doing wrong?
Shall I post the entire project now?
Cheers
Michal -
Ok. If you have only one MainMenu (withot submenus) then it's normal that there is just one entry. Titlesetmenus are in the other ifo files. Nevertheless if your MainMenu should be looping, you should find the line with the 1. Post command. Should look like this:
GUI for dvdauthor:
Then 'technically' it should loop ok. If it doesn't, there is probably something wrong with the audio file. If there is only one menu (here the MainMenu), it is even impossible that the menu plays the audio from a 'following' menu, as this would be in another vob file...
GUI for dvdauthor:
yeah I know... but that's exactly what's happening
...shall I know post you some files?
OH! I have now solved that problem as well!!! My Fault again or just a really big coincidence...the thing was:
I had a audio nr.1 in menu nr.1
and then audio nr.2 in menu nr.2
but what showed up now was that audio nr.1 was an audio file that contained both audio nr.1 and audio nr.2
so my nr.1 menu audio looped properly but it was just two audio (in one) instead of just one :P
Thank you all for all that help you have been given me...and that your answers were so fast!
and borax GfD is a really really nice program I don't know what I would have done without it THANK YOU!!! YOU REALLY OWN!!
Regards and BIG thanks
Michal -
Oh! Now when my whole project works fine there showed up that it's to big to be bruned on a DVD-R (4,7 GB) my project (the DVD-folder) is 4,49 GB large and the DVD is 4,38 GB
is there a way to make my project a bit smaller or will I be forced to split this project in two? While I converted my .avi which was 949 MB large to .mpeg, I got a new file which was 1,89 GB ... why does the size go up that much during the convertion?
one thing that also is weird is that GfD shows that the project total size (in the left "folder window") is just 3998 MB...and when I check the size of the created VIDEO_TS the size is 4060 MB -
Originally Posted by träskmannen
hm DVD Shrink just freezes when I try to open my project in it :S -
If it is elementary mpeg2 material (as you use MuxMan it surely is), you can also 'shrink' the video in GfD itself.
You can either set the shrink factor for each title individually or set a 'global' shrink factor which will be applied to all videos.
Check it out here:
http://download.videohelp.com/gfd/Help/VideoFileDialog.html
An sorry, the algorithm to calculate the size has only an accuracy of about 1 or 2%. If I would calculate very accurate, it would take a lot of time which I try to avoid.GUI for dvdauthor:
REALLY COOL!!! One more needed option in GfD that works perfectly
...I'm sooo happy that I found your program...and once again congratulation ...you are making a really good job!!!
just one weird thing that occured to me is that while authoring with dvdauthor instead of muxman the videos are hacking sometimes during "fast action" (for example a car chasing)...but while using muxman it works great so nvm
I have now burned my DVD and it works as it should !!! THANK YOU ALL FOR YOUR HELP I REALLY APPRECIATE IT!!!
Thank you!
Michal -
ok so I have now successfully burned my DVD but when I open it at my DVD-player (TV) I see that the highlight color was to light (colors are always a bit different at my comp and at my TV...don't know why :S) ...and I had white as normal color...so the user don't see where he is standing (on which button). Can I change this in some way now or do I just need to burn the whole project again?
That's normal. There are a lot of reasons for this 'mismatch' (different color space: RGB<>YUV, gamma correction...)
On the finished DVD:
No.
In the ifo/vob files:
Yes, with dvdsubedit or pgcedit and some others too. But if you are not familiar with these programs, it is probably easier to rerun the project in GfD...
This is a 'known' problem. Should be much better with the new version (coming soon...)GUI for dvdauthor:
ok cool...nice that you are updating the GfD so often too
...well nvm of the colors...they are light but that's not a big problem
the main thing is that the DVD works perfect!!
thanks
Michal -
one more question about SubtitleCreator...why doesn't it read all types of subformats... when I try to open a .txt file which has this paticiular structure:
Code:00.00.01 Text
Code:Error reading subtitle number 1. (Indatasträngen hade ett felaktigt format.) (swedish of = The input had wrong format)
regards
michal -
It's not SRT:
Code:1 00:00:09,160 --> 00:00:12,080 Two minutes to curtain up, c'mon! 2 00:00:12,080 --> 00:00:13,720 Two minutes to curtain up.
You seem to only have a start time.
Subtitle Workshop can read and write most subtitle text formats, so give that a try.
If you look at the tools it has you may be able to build an SRT file, using automatic duration say.
But you will need to manipulate your text file somewhat, perhaps in Excel. -
ah ok I didn't know that SubtitleCreator also needed a ending time ... At first I this format of subtitles {100}{200} Text... but I needed to synhronise them and I needed to convert them to "time" subtitles first...so I did that but I converted them wrong because I erased the ending time ... (dind't know I would need it later in SubtitleCreator...thank you it works now!!!!
Cheers
Michal -
something weird just happend with my GfD again
when I try to view a animated menu preview (View-->Animate (AVS) Menu Preview) I got an error message :
what's the problem I have always been abel to view my menu that way
WHAT?! Now when I close my open project, saved it and try to open it again GfD doesn't open at all and I got a new error message :S:
please help what has gone wrong (what's wrong with MSCOMCTL.OCX) with GUI for dvdauthor
I have now tried to reinstall the program but I still got the same error message when I try to start up
Michal -
well never mind I fixed that problem with a system restore
The two numbers here are the beginning and ending time, in frames, for displaying the subtitle.
Subtitle Workshop can read that and convert it to a second-based format, like .SRT. -
yeah that can SubtitleCreator as well
and that's exactly what I have done
during my last creation of DVD
a weird subtitles bug occured...while I downloaded a .srt subtitle and converted it to .txt with the frames structure {100}{200} Text...then the new .txt file wasn't synhronised like the .srt :O really weird why does this bug occure?
michcio -
btw I would like to do my own DVD-authoring tutorial... which discribes programs which I use...and how I make my DVD from the beginning to the end...(to help some people and to get response)..any idea where I could write this tutorial?...here on the forum? then where?
Possibly you specified the wrong fps when converting from seconds.
Code:{1}{1}23.976 {0}{24}Hello!
is the fps.
Usually 23.976. 29.97 or 25.
Subtitle Workshop has an FPS setting on the left.
https://forum.videohelp.com/topic77896.html -
ah cool!! it really helps to check to fps of my video thanks!!!
and ty for the sites to create my own guide
regards and thanks!
michcio -
ok I'm now done with my guide
...please take a look at: https://forum.videohelp.com/topic353434.html
Nice guide!
I only miss the topic of subtitle colors (either 'pre authoring' with a palette in GfD or by 'after authoring' correction with dvdsubedit or similar).GUI for dvdauthor:
SubtitleCreator and Windows 7
By sambat in forum SubtitleReplies: 0Last Post: 19th Oct 2010, 11:15 -
SubtitleCreator problem
By Grendel007 in forum SubtitleReplies: 4Last Post: 15th Sep 2009, 01:45 -
Can't get SubtitleCreator to work.
By GangstaRap in forum SubtitleReplies: 0Last Post: 26th Jan 2009, 12:33 -
GUI for DVDAuthor File format (.gfd files)
By tacman1123 in forum Authoring (DVD)Replies: 6Last Post: 6th Jun 2008, 16:45 -
SubtitleCreator 2.2.2 problem
By m_tawfik15 in forum SubtitleReplies: 4Last Post: 6th Jun 2008, 12:11
