My laptop has 2 connections on it- a wireless one for the coffeeshop and a dialup for my ISP from home.
Lately, but not always, opening a page in the browser will activate the 'try to connect via dialup' even when using the wireless.
Where the heck do you look for a prob like this?
Look in your browser's connection settings. For IE7, click on the Tools bar at the right-hand side of the menu bar. For IE6, click Tools on the menu. Then, for both, select Internet Options then the Connections tab. You'll see three radio buttons:
() Never dial a connection
() Dial whenever a network connection is not present
() Alway dial my default connection
Select the first option, close the window and restart the browser. If it is already selected, the problem will lie elsewhere.
Not guaranteed, though!John Miller -
I admire a user like ahhaa. He had a problem and asked a question instead of coming on with a "Vista sucks' post.
The vast majority of Vista "problems" are:
- The user doesn't know how to do or set up something especially if the same function was done differently or didn't exist in XP (or Windows 3.1 for that matter).
- Old and incompatible drivers
- Old and incompatible software
- Inadequate hardware
Neatvideo strange behavior
By themaster1 in forum RestorationReplies: 51Last Post: 12th Feb 2012, 08:11 -
WMP11 odd behavior.
By bizzybody in forum Software PlayingReplies: 2Last Post: 26th Apr 2010, 06:06 -
Unusual behavior of PC clock
By Seeker47 in forum ComputerReplies: 7Last Post: 22nd Aug 2009, 12:34 -
frustrating behavior
By digiflux in forum ffmpegX general discussionReplies: 4Last Post: 5th Oct 2008, 10:16 -
What is the difference between Vista basic and Vista home premium?
By davidsama in forum ComputerReplies: 18Last Post: 27th Oct 2007, 12:01
