Hi all,
i had this report after trying to convert a vcd format to ipod format... the target file is empty
Encoding started on Sun Jun 29 05:11:59 SGT 2008
FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
Mac OSX universal build for ffmpegX
libavutil version: 49.0.0
libavcodec version: 51.9.0
libavformat version: 50.4.0
Input #0, mpeg, from '/Volumes/VCD_36281_D1_1/MPEGAV/AVSEQ03.DAT':
Duration: 00:56:31.7, start: 0.826667, bitrate: 1411 kb/s
Stream #0.0[0x1c0]: Audio: mp2, 44100 Hz, stereo, 224 kb/s
Stream #0.1[0x1e0], 25.00 fps(r): Video: mpeg1video, yuv420p, 352x288, 1140 kb/s
Codec type mismatch for mapping #0.0 -> #0.0
Pls help, thx
Your source file has the audio stream (#0.0) mapped before the video stream (#0.1). This is reverse from what the ffmpeg engine expects. You may fix this "Codec type mismatch for mapping"-error by indicating that the streams are reversed. To do so, check the "Invert mapping" checkbox in the audio tab.Originally Posted by happyriceman
I ought to thank, too.
Just downloaded ffmpegX to convert from VOB to DV. Got empty files as result and no error message. Browsed the web to find a solution. Here I found it! It was far from obvious to me what the problem could be. BTW, would assume that an application like ffmepeg should be able to detect the ordering of video and audio itself??
best format and size to convert a vcd dat file to for archiving?
By perfection in forum Newbie / General discussionsReplies: 3Last Post: 1st Apr 2012, 03:59 -
Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
By bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 09:15 -
Converting MPEG to 3GP --> Empty Target File?
By SnakeGirl in forum ffmpegX general discussionReplies: 6Last Post: 11th Jan 2008, 00:14 -
Which is the Best Tool for converting DVD to iPod format?
By mr_jbloggs in forum Video ConversionReplies: 5Last Post: 1st Oct 2007, 21:07 -
converting from Real Audio to iPOD format
By tigermoon0 in forum ffmpegX general discussionReplies: 0Last Post: 15th Aug 2007, 02:49
