I have windows and in accessories>>entertainment there is a 'sofware' called record sound, however u can only record upto 60 secs.
can someone please tell me if there is a free software that i can record stuff on for atleast an hour? i wna make a voice diary. lolz.
please help.
a little known fact is you can use Windows Movie Maker for recording audio only (not just video).
Just go tools/ narrate timeline and follow the bouncing ball -
If you just want to make voice recordings than MP3directcut would be the ideal tool. It allow you to record straight into mp3, with options to cut or move parts of recording. And it is very easy to use.
I remember once there was a diary software which allows you to write your daily entries and record voice clips linked to your diary entries. Try to search for diary software
Does software for video voice recognition exist?
By mazinz in forum ComputerReplies: 7Last Post: 16th May 2011, 12:36 -
Any good voice changing editing software?
By overloaded_ide in forum AudioReplies: 7Last Post: 14th Dec 2009, 21:39 -
How to record sound over the movie... Voice Over? Dubbing?
By UmmAddan in forum Newbie / General discussionsReplies: 3Last Post: 3rd Nov 2008, 19:23 -
A good software to modify the voice
By Cunhambebe in forum AudioReplies: 3Last Post: 9th Jun 2007, 05:44 -
How do I record a my voice at a good sound level?
By OM2 in forum Newbie / General discussionsReplies: 6Last Post: 15th May 2007, 13:31
