I am trying to convert a couple of my holiday AVIs to a supported video type for my Samsung G600 mobile phone.
I believe it supports 3GP, I'm not sure about MP4 - can anyone recommend some good software to convert and resize to a format that will play on this phone?
Many Thanks,
Steven
NB: I tried using Mpeg Streamclip 1.1 and converted to MP4, but my phone just says "unsupported content" when I try to play it
Portables are very picky on the specs they are able to playback
If the manual and/or support forums for that model don't tell you the EXACT specifications for both video and audio (like codec, bitrate, size, container, type of frames, like b frames, etc...) you might have to post a sample clip here, otherwise you are just guessing on what it can playback. You can try to analyze it yourself with mediainfo and gspot and avinaptic to figure out some of the info. -
Used Gspot to determine the following from a video file that came already on the phone:
codec: mp4v
Mpeg 4 video
192 kbps
Codec status undetermined
mmp4: MPEG-4/3GPP Mobile Profile (.MP4 /.3GP) (for NTT)
- 3gp5: 3GPP Media (.3GP) Release 5
- 3gp4: 3GPP Media (.3GP) Release 4
Recommended Display Size: 352 x 288
audio: mp4a: MPEG-4 AAC LC
info: 16000Hz 64 kb/s tot , stereo (2/0)
Not sure if there is a program that can recreate this? -
You still need more information on fps (most mobiles only support crappy 15fps only)
Try mediainfo (view=>text)
If you do a google search, kingconvert and xilisoft apparently both work (unfortunately not free)
http://www.whatmobile.net/forumvb/showthread.php?t=22208
One user reported the ipod profile working. If so, then you could possibly use freeware apps like videora or avidemux which both have ipod profiles; just match the specs.
good luck -
Try http://www.dvdvideosoft.com/products/dvd/Free-3GP-Video-Converter.htmOriginally Posted by sterankin
Used their youtube to ipod, and mp3 converter for a while, and they work. Their video tool has somne pixelation, but on a small screen, expectation on a phone/ipod, and free. Can't complain. -
This worked perfectly, thankyou very much for your help!Originally Posted by SingSing
video conversion for mobile phone
By sumeshkri in forum Video ConversionReplies: 1Last Post: 3rd Nov 2010, 17:49 -
mobile phone issues
By bigmacsexgod in forum Newbie / General discussionsReplies: 2Last Post: 14th Jun 2009, 14:40 -
transferring files from the PC to mobile phone
By sumeshkri in forum AudioReplies: 3Last Post: 19th Sep 2008, 07:26 -
Convert 16:9 AVI to MP4 and resizing for mobile phone (?)
By wldworld in forum Video ConversionReplies: 2Last Post: 6th Jul 2008, 23:48
