I searched the best of my ability and couldn't find my question addressed, at least not directly. I have a video taken with a MiniDV camcorder that needs some audio editing. I'm trying to figure out how to demux the audio into WAV files, edit it in Audacity (preserving the length), and then remux it. I found this post detailing how to extract the audio using VirtualDubMod but I can't find any detailed instructions on how to remux it. I'd like to perform all this before I do any other editing or convert to any other formats. Any help would be much appreciated.
What editing software are you using? You should be able to select the track, render as 48KHz/16 bit WAV, edit, save edits, then bring the new track into your timeline in place of the original. If you're using any of the major editing softwares it should be easy to do it this way.
Not sure yet. I downloaded Avid Free DV but haven't installed it yet. My only real experience is with Windows Movie Maker. I'm open to any suggestions on which free video editing software would be good for this task.Originally Posted by stantheman1976
Thanks, I'll check it out.Originally Posted by JohnnyMalaria
Steps to repair a partially downloaded .avi that has a missing header.
By torrentcrazy in forum User guidesReplies: 12Last Post: 4th Feb 2015, 20:11 -
[solved] editing MKV without remuxing
By lovelove in forum Newbie / General discussionsReplies: 4Last Post: 12th Aug 2011, 10:09 -
remuxing problems
By kcmccombs in forum Blu-ray RippingReplies: 5Last Post: 19th Jul 2011, 10:00 -
Strange remuxing results of AVI
By 201flyer in forum Video ConversionReplies: 0Last Post: 20th May 2010, 02:32 -
Bitrate Cap on Remuxing?
By Ast0reth in forum Video ConversionReplies: 2Last Post: 11th Sep 2009, 08:25
