Hello, I would like to know is it's normal to convert my DivX in SVCD in 4 HOURS !!! :-( My cpu is 1.3Gz and 512mb. I first extract audio in a .wav file with virualdub, after, I convert .avi to SVCD, but it's long, too long. I let Full Screen (keep aspect ratio), and bitrate between 1800-2000.
Somebody can help me ?
thx
If time is your major consideration - can't offer much more improvement with settings being tweaked - get a dual cpu system! I have a dual amd xp1700 and can encode from dvd to vcd at about 83% of the movie time. ie 130 min movie takes about 107 min to encode. Frees up the wait time substantially.
ok, thx !
and another problem I have, how to be sure of the final file size ? ex: i've a 700mo, 95min, movie (divx), so, of cours, 2 cds are needed for it, but i should be interesting to pub the max bitrate to fit it on 2 80min cds ;-)
i tried the calculator in on of the guide, but doesn't success with it ...
I use TMpgEnc to convert MOV to DIVX. But the quality of AVI isn't good
By natong in forum Video ConversionReplies: 0Last Post: 11th Apr 2009, 01:21 -
why convert a MKV to DVD format took more than an hour ?
By c1steady in forum Video ConversionReplies: 2Last Post: 1st Apr 2009, 20:34 -
It took 11 hours with TMPGEnc 3 to make a 2 hour video folder
By nhbfan12345 in forum Authoring (DVD)Replies: 3Last Post: 9th Dec 2008, 15:18 -
Does TMPGEnc DVD Source Creator 4 convert Divx(Avi) with audio?
By Plarocks in forum Authoring (DVD)Replies: 9Last Post: 10th Sep 2007, 18:11 -
How to convert Mpeg2 to DivX using TMPGEnc and SimpleDivX
By rwmol in forum User guidesReplies: 14Last Post: 30th Jul 2007, 00:57
