    May 2008
    Hey guys,
    so i've resolved my last issue and have figured out several ways i'll be able to hook my PC to my TV as a primary monitor. My next question is which method to use. With the graphics card i'll be using I can easily use an s-video cable. I could also run the graphics out of the VGA, through a converter box and into the component video pins on the TV. I've heard the quality of the s-video connection isn't the greatest and was wondering if the 2nd method (VGA to component) gives a better picture. I don't want to run out and buy a converter box if it will give me the same quality as the s-video
    thanks for the help so far, hope my explanation was clear
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    What TV? SD or HD? Connector choices?
    What Display Card?
    What VGA convert box?
    http://www.kiva.org/about
    May 2008
    whoops
    May 2008
    What Display Card?
    It's a flat screen tube TV (sylvania ssgf4276) with s-video and component video connectors
    The video card is an ATI radeon HD 2400 pro that has s-video, VGA and DVI outputs
    I dont know which converter box i would get yet, i would decide once i determine which connection would get me the best picture. If converting VGA to component gives a better picture than s-video then i will buy a converter box. If there's no difference, i won't buy one.
  5. Member edDV's Avatar
    Mar 2004
    What Display Card?
    So this is a standard def CRT TV?
    Unless your ATI HD 2400 TV out connector has only 4 pins, it probably supports analog component with the proper cable. Call the card maker and see if they supply the cable. Otherwise use an S-Video cable on the same connector.
    See this thread for similar request.
    https://forum.videohelp.com/topic352950.html
    May 2008
    ok thanks...and yes its a standard def crt tv
