What's the proper aspect ratio for wide-screen format? I ripped and burned Ghost in the Shell and it's like watching a movie that hasn't been formatted to fit the screen, i.e. you see the center parts but the left and right sides are out of your plane of view...thanks
What are you using to encode?
If using tmpgenc, then choose 4:3 display on the video tab next to aspect ratio and under the advance tab set your source aspect ratio to what the movie is, usually 16:9 525 line (ntsc) or 16:9 625 line (pal) and under that next to video arrange method, choose full screen (keep aspect ratio)
How to Maintain Correct Aspect Ratio in PotPlayer with Full Screen
By drstew12 in forum Software PlayingReplies: 1Last Post: 20th Dec 2011, 19:25 -
Can't get aspect ratio 16:9 to fill the screen when play DVD movies.
By Herbert Smith in forum DVD & Blu-ray RecordersReplies: 2Last Post: 15th Sep 2010, 06:37 -
Split screen, keep aspect ratio and use half of 2 different videos ?
By boulder in forum EditingReplies: 10Last Post: 10th Nov 2009, 11:30 -
DV 4:3 to 16:9 aspect ratio conversion
By hysteriah in forum Video ConversionReplies: 6Last Post: 9th Dec 2007, 02:40 -
Aspect ratio Conversion?
By Colmin in forum Media Center PC / MediaCentersReplies: 4Last Post: 25th Sep 2007, 17:18
