I hope this is in the right forum, it is a beginner question.
My brother just bought a high def tv and we know nothing about the format.
Can I play high definition video files from my pc to a high def tv screen?
Peace
“He who makes a beast of himself gets rid of the pain of being a man.”
Depends. Your new HD TV would need to have a VGA (PC) input or you would need a HDMI/DVI output on your PC and a HDMI/DVI input on your TV.
Google is your Friend -
Thanks for the reply Krispy Kritter.
I have the HDMI inputs on the tv that's no problem, but the pc I will/might be using is old. Is there any type of adaptor to carry the audio/video signals from my PC?
peace“He who makes a beast of himself gets rid of the pain of being a man.” -
No VGA (PC Port) on the new HDTV? Most have them.Originally Posted by thecrock
What display card do you have in the computer? Or, if on the motherboard, what is the computer model number?Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Yes there is a pc port on the tv but I'm wondering about the leads I'll need going from the pc.
You need to give some more details about the PC (specifically the graphics card it has) and then the advice will be targetted. However, in the meantime...
A PC port on the TV would suggest it takes a VGA cable - if you have an old PC then in all likelihood this will be the same port you use to plug in the monitor for the PC. If this is true, then simply connect the VGA cable from your computer to the TV. See thic pic below.
If you have a slightly newer PC you might have two outputs on the graphics card - a VGA and a DVI port (see the same pic - it is a little blurry). You can either use the VGA port, or buy a DVI-to-HDMI converter and use the HDMI port on the TV. If your PC is more recent, you may have two DVI ports on the graphics card.
Which ever way you choose, this will only get you visuals. To get sound you need to connect the line out port on the back of your PC's sound card to the sound input on the back of the TV. There are different types of connectors/ports that could be used (e.g. 3.5mm, phono, optical etc....) but this all depends on what you have on the PC and the TV. Post with some more information (or even better - pictures) and you'll get the right advice!
High Def for Canopus Let's Edit 2.
By ralphb in forum Newbie / General discussionsReplies: 0Last Post: 4th Mar 2011, 10:29 -
High def onto a DVD?
By enchant3 in forum Authoring (DVD)Replies: 5Last Post: 17th Feb 2011, 07:17 -
What do I need to make high def movies?
By so in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2009, 18:30 -
How may I record in High Def and Playback in High Def ?
By MacPCConsultants in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 7th Jun 2008, 17:28 -
high def and DVD-VR
By feh in forum Newbie / General discussionsReplies: 2Last Post: 19th Feb 2008, 14:03
