I'm able to extract the .m2ts from the Blu-ray disk and extract both the audio and video streams from that. I can play the .m2ts file flawlessly.
I remux the audio and video into a .mkv container and it has trouble decoding the same audio stream (DTS-HD Master Audio).
CoreAVC w/ Haali Media Splitter
AC3Filter as my preferred decoder
FFDShow to decode everything else
Media Player Classic for playback
... this is pretty much all I have installed. No PowerDVD or anything.
Why am I able to decode the audio fine in the .m2ts container and not in the .mkv container? Codec setting? Remux setting?
Edit: Yes, I was able to extract the core DTS stream and use this, but I'd rather use the DTS-HD MA if possible.
ejp.
In order to play DTS-HD audio you must have an amplifier with HDMI 1.3A.
I'm afraid that Media Center PC won't support DTS-HD just yet, also MKV container is not suitable for this audio stream anyway. If you want to keep DST-HD you must use TS container instead. The only player that i know supports DTS-HD is M6500A, where you can get anywhere in the internet, but I found:
DATOptic.com offers High Def Network Media Player - TVIX (DVICO is the manufacture) bundle with a Software to convert M2TS, EVO, VOB... to MKV,TS, DVIX, XVID... Which I use to bring the size of 28GB to a DVD-R. Here is what they state:
Our M6500A comes with software and instructions of how to convert M2TS (Bluray), EVO (HDDVD), VOB (DVD)... to MKV (H.264), TS, XVID, DIVX, AVI formats at full 1080p. From 18GB - 29GB file to a DVD-R or DL DVD-R.
Now support:
* DTS-HD audio (TS container)
* Convert DTS-HD to DTS, Dolby TrueHD to AC3 5.1
* Size prediction...
Email to support at datoptic.com to get a copy
I bough TWO of TVIX - M4100SH and M6500A, the only one supports DTS-HD is M6500A and I have to play it through my Onkyo TX-SR605S via HDMI connection, where my BOSE Life Style could not play
Hope this help! -
If you have a playstation 3 you might try streaming it to that then to your stereo equipment. I believe the playstation 3 can play m2ts files.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
I may be wrong. I don't think PS3 supports M2ST with DTS-HD audio.
Also M2TS is TOO BIG (20~30GB per movie) for a computer storage, where TS ans MKV are much more space efficient
Check out the MKV and TS container format! -
http://www.pcworld.com/article/144399/ps3_firmware_update_exposes_dtshd_audio_abilities.html
Btw I stream .m2ts video to the PS3 via TVersity ,however just change extension to .mpg before streaming..
I'll have to try streaming a sample with DTS audio and report....." Who needs Google, my wife knows everything" -
Learn something new everyday !
But still love my TVIX, which can see FOUR computers in the network -
Just an update.
limHD-310s - A High Definition Network Player has the ability to convert DTS-MA/True-HD (7.1) to DTS-core/AC3 (5.1) on fly.
This solve the problem of playing DTS-MA/True-HD (7.1) in non DTS-MA/True-HD (7.1) supported AV system.
Check this unit out.
http://www.datoptic.com/cgi-bin/web.cgi?product=limHD310s&detail=yes
FireWire2
Merge .DTS track with mkv to play on LG BD570 Blu-Ray player
By kcsongi in forum AudioReplies: 2Last Post: 5th Feb 2012, 13:23 -
How to convert blu-ray (m2ts) to mkv or mp4 properly?
By michaellee0101 in forum Video ConversionReplies: 1Last Post: 20th Apr 2011, 08:24 -
mkv to m2ts playing on my blu-ray player
By PSS2 in forum Authoring (Blu-ray)Replies: 6Last Post: 29th Jan 2010, 17:24 -
remuxing a blu ray with multiple small m2ts files
By kevcampbell in forum Blu-ray RippingReplies: 2Last Post: 23rd Nov 2009, 12:08 -
Blu ray m2ts files not in order? mkv conversion
By davidc78au in forum DVD RippingReplies: 3Last Post: 11th Feb 2008, 12:39
