I am trying to recode 35 minutes of Full-HD .mts (Panasonic AVCHD - 3.3 GB) as WMV and it takes about 12 hours.Surely this is a little over the top?
I note that .wmv is the only video I can work with on my Intel Core 2 machine with 4 GB of memory. Anything else just judders and jars.
I am using a bitrate of 8000 instead of the default of 1000 (of course). However I'll have to leave my machine on for several weeks if I want to transcode everything. Is there a better way?
Martin
Results 1 to 11 of 11
I can play full HD using e.g. Media Player Classic and the CoreAVC codec through Haali. But all video editors cannot cope - be it Vegas, Pinnacle STudio... ALl that works with no hassles at full HD is Windows MOvie Maker with WMV files.
But the problem now is how to speed up the transcoding.
Martin -
Interesting contribution... if I wanted to resize, why would I use HD in the first place?Originally Posted by Soopafresh
Martin -
Because the visual quality is MUCH better than filming at SD resolution - even when you resize to SD dimensions.
If you wanted HD, you should have bought an HDV camera instead. AVCHD is still ironing out the kinks. Every camera does it differently, so no program handles all footage the same, and hence there are few good conversions tools.
You wanted a solution to the time taken - Soopafresh suggested reducing the size because this will reduce the time requirements. It may be that you have to face 12 hour encodes until the whole AVCHD debacle is sorted out.
HDV, on the other hand, is a doddle in comparison.Read my blog here.
AVCHD on hard drive: creating new AVCHD folder structure
By Phil_W in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 1st May 2011, 15:46 -
software to batch convert m2ts format avchd to mts avchd?
By masterpug in forum Video ConversionReplies: 0Last Post: 14th Aug 2010, 02:06 -
AVCHD Lite Help: WMV and/or XviD conversion
By tarrickb in forum Video ConversionReplies: 43Last Post: 31st Jul 2009, 21:55 -
Converting AVCHD to wmv
By Roddytoo in forum Video ConversionReplies: 0Last Post: 20th Feb 2008, 12:15 -
How to convert wmv clip so its properties match other wmv clips
By sohaibrazzaq in forum Video ConversionReplies: 4Last Post: 4th Aug 2007, 10:16
